Services Module SM-SRE-910-K9 error log and perfomance issue. %WAAS-RE-3-690412: Unknown frame type from peer:
jan.mierczi
Recently we get many compliants in our company about performance etc. Everybody states that it is somethis wrong with WAAS. We uses SM-SRE-910-K9. I got a case and trying understand if this is refers to SRE or simple another problems.
The logs appearig:
May 8 08:09:39 so_dre: %WAAS-RE-3-690412: (289120:33) Conn(id=10629) client-ip=10.44.XX.XX,client-port=63779,server-ip=XX.XX.245.73,server-port=50096 from peer XXXXXXXXXX-013f563e8c04-79779521: Unknown frame type from peer: XXXXXXXXXX type=0 comp_type=3 sock=0 byte_pos=70 data:0x0d03000005000c171000
Could you tell me please if this log is really important and how to split WAAS issue from another problems?
Hitesh Vinzoda
Level 4
Level 4
I think you are hitting a bug
Unknown frame type from peer -- WAAS-RE-3-690412
CSCvc44940
Description
Symptom:
Connections will randomly dropped, and WAAS logs will show below2016 Dec 8 21:25:24 HH-TX10-WAW001 so_dre: %WAAS-RE-3-690412: (157561:49) Conn(id=474385) client-ip=10.67.195.95,client-port=58576,server-ip=202.173.28.250,server-port=80 from peer 88:5a:92:88:40:f4-0141bbb190d7-d2d9a811: Unknown frame type from peer: 88:5a:92:88:40:f4 type=0 comp_type=3 sock=0 byte_pos=250 data:0x0100004703015849cfc4
Conditions:
Workaround:
N/A
Further Problem Description:
Customer Visible
Notifications
Save Bug
Open Support Case
Was the description about this Bug Helpful?
(0)
Details
Last Modified:
May 5,2017
Status:
Fixed
Severity:
2 Severe
Product:
(1)
Cisco Wide Area Application Services (WAAS) Appliances
Known Affected Releases:
(2)
6.2(1a)
6.2(3a)
Known Fixed Releases:
(2)
6.3(0.160)
6.2(3c)2
Upgrade to above recommended versions or contact TAC.
Hitesh
Please rate useful posts.
Hitesh Vinzoda
Level 4
Level 4
CSCvc44940
Description
Symptom:
Conditions:
Workaround:
N/A
Customer Visible
Notifications
Save Bug
Open Support Case
(0)
Details
Last Modified:
May 5,2017
Status:
Fixed
Severity:
2 Severe
Product:
(1)
(2)
6.2(1a)
6.2(3a)
(2)
6.3(0.160)
6.2(3c)2
Hitesh
