SHDSL
Oscar Cardiel
Hello guys,
I am trying to configure a shdsl module but I don't get to up the Atms interfaces created. I think is a wire problem because I see the following message when the show controller shdsl command.
Controller SHDSL 0/3/0 is UP
Group (0) info:
Type: 4-wire g.shdsl, status: Configure Firmware
Interface: ATM0/3/0, hwidb: 0x6489FDD0, UTOPIA phy 0
Configured/active num links: 2/0, bit map: 0x3/0x0
Line termination: CPE, line mode: 4-wire, Annex-A, PMMS disabled
Line coding: 16-TCPAM, configured/actual rate: 4608/0 kbps
SHDSL wire-pair (0) is in DSL DOWN state
Termination: CPE, line mode: 4-wire, Annex-A
Line coding: 16-TCPAM, configured/actual rate: 2304/2048 kbps
CONNECT state: MAIN_PRE_ACT, cond: EXCEPTION, reason: NOT_CONVERGED_ON_SC
SHDSL wire-pair (1) is in DSL DOWN state
CONNECT state: MAIN_INIT, cond: EXCEPTION, reason: NOT_CONVERGED_ON_SC
My configuration is the following:
controller SHDSL 0/3/0
termination cpe
dsl-group 0 pairs 0, 1
shdsl 4-wire mode enhanced
shdsl annex A
shdsl rate 4608
dsl-group 1 pairs 2, 3
shdsl annex A
shdsl rate 4608
interface ATM0/3/0
no ip address
ip route-cache flow
no atm auto-configuration
no atm ilmi-keepalive
no atm address-registration
no atm ilmi-enable
pvc 8/35
encapsulation aal5mux ppp dialer
dialer pool-member 2
interface ATM0/3/1
no ip address
ip route-cache flow
no atm ilmi-enable
pvc 8/35
dialer pool-member 4
with their Dialers configuration.
What do you think about?
thank you very much in advance.
28 Replies 28
Dear Patrizio,
I've tried this versions:
- c2900-universalk9-mz.SPA.153-2.T
- c2900-universalk9-mz.SPA.152-3.T3
- c2900-universalk9-mz.SPA.152-2.T4
Telecom says it is a wiring problem between the router and the modem.
On the modem I've 8 bnc-n3 (4 pair). I'm not sure that my custom cable is correct.
thx
Salvatore
Dear Salvatore,
i think there is an impedance mismatch , you should have rj45 port on the Telecom modem and not bnc .
If they use bnc and you use rj45 must use baloon to adapt impedance !
What modem it is an Aethra ?
Dear Patrizio,
as you can see in the attached image the modem is Albis SA44.
and i used this impedance adapter (4 adapter....one for line).
thx
salvatore
Dear Salvatore,
do you use the original cisco cable for the card EHWIC-4SHDSL-EA ?
How do you connect the  impedance adapter to the cisco cable ?
Have you followed how the connection are done inside the impedance adapter and in the
"RJ adapter" between the "impedance adapter" and the cisco rj cable ?
Please note that sometime using an rj11 male inside an rj45 female may not connect properly .
Patrizio
Dear Patrizio,
at this moment I've a custom cable. I started from cisco documentation and I've created this cabling (see attach).
I also tried cabling from original cisco cable without success.
Salvatore
Salvatore ,
i was looking at the modem , i think i see an alarm led lite , no led for g703 or shdsl line .
Can you do a kind of loopback on g703 and see if shdsl line led come up ?
(any modem manuals ? or ask telecom)
Patrizio
Dear Patrizio,
the only led ON is the power. The alarm LED is not lit, it's just a reflection.
Telecom says that under normal conditions the LEDs should be off. If I try to disconnect the coaxial cables I see light up the red alarm light. if I try to do a loop the light goes off. no green light with the exception of power.
I found an online store that sells dual-baloon. I could try to buy these:
http://www.denicolai.it/container.asp?fchi=scheda&cod=2351320&famchi=N2H&web1=N2.
is my last hope.... :-((
The device in picture is an SHDSL/G.703 converter. So you have  E1 service, that you cannot connect to Cisco SHDSL interface, not even with baluns.
Eiither use Cisco E1 card to connect to G703 interface, or bypass the converter, and connect SHDSL directly.
Hi ! How does it cost this module shdsl ? In € ?
p.mafara
Dear Salvatore,
i hope you will resolve the issue with the dual-baloon .
Ciao e tanti auguri,
Patrizio
Dear Patrizio,
I can not find a way to have this line running.
- Tried with Cisco cable splitted in four rj11 and connected to telecom modem with four bnc n3: don't work.
- Tried with custom rj45 to four rj11 and connected to telecom modem with four bnc n3: don't work.
- Tried with custom rj45 and connected directly to the line: don't work.
- Tried with dual-baloon: don't work.
This is my configuration:
controller SHDSL 0/1/0
dsl-group 0 pairs  0, 1, 2, 3 ima
interface ATM0/1/IMA0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
no ip route-cache
interface ATM0/1/IMA0.1 point-to-point
ip address 85.35.11.126 255.255.255.252
ip nat outside
ip virtual-reassembly in
no ip route-cache
pvc 8/35
  protocol ip 85.35.11.125
  oam-pvc manage
  oam retry 3 5 1
  encapsulation aal5snap
this is my controller:
SAGA-SCURCOLA-GW#sh controllers shdSL 0/1/0 brief
Controller SHDSL 0/1/0 is UP
  Hardware is EHWIC-4SHDSL-EA, rev 0 on slot 0, hwic slot 1
  Capabilities: EFM: 2-wire, EFM-Bond, Annex A, B, F & G
                ATM: 2-wire, Mpair, IMA, Annex A, B, F & G
  CPE termination
  cdb=0x30C52CD4, plugin=0x2BD5E6A8, ds=0x30C3ED74 base=0x10200000
  FPGA Version is A11
  NPU Source: System
  NPU Firmware version: SHDSL_EA_FW_20120508034306
  Vendor: Infineon, Chipset: SOCRATES-4e
  PHY Source: System
  IDC Firmware version: 1.7.2.0
  DFE Firmware version: FW_BETA_120111A
  Group info:
        Type: IMA over g.shdsl status: Down
         Ethernet Interface: Ethernet0/1/0, hwidb: 0x2BD663A8
         ATM Interface: ATM0/1/IMA0, hwidb: 0x2BDC8868
  Currently active interface:
        Configured/active num links: 4/0, bit map: 0xF/0x0
        Line termination: CPE, Annex: auto
        PMMS disabled,Line coding: AUTO-TCPAM
        Configured/actual rate: AUTO/0 kbps
        Loopback type: None
        Dying Gasp: Present
        SHDSL wire-pair (2) is in DSL DOWN state
        SHDSL wire-pair (3) is in DSL DOWN state
        RMII Device Stats at NPU:
                tx_packets: 0,  rx_packets: 0
                tx_bytes: 0,  rx_bytes: 0
                tx_dropped: 0,  rx_dropped: 0
                tx_err_fcs: 0,  rx_err_fcs: 0
                tx_mac_pause: 0,  rx_mac_pause: 0
        ATM Stats at NPU:
        IMA Group Stats:
                tx_cells: 0,  rx_cells: 0
                tx_oam_cells: 0,  rx_oam_cells: 0
                tx_clp0_cells: 0,  rx_clp0_cells: 0
                tx_idle_cells: 0,  rx_crc_err_cells: 0
I do not have any support from Telecom Italy and do not know what to do.
Any help is greatly appreciated.
Thanks for your patience.
Salvatore
Salvatore,
i agree with Paolo .
( I did not see Paolo reply before my last answer )
At this point you should "bypass the converter, and connect SHDSL directly".
Dear All,
I tried with converter but still don't work.
Salvatore Silvestri wrote:
Dear All,
I have explained you above why.When connected to the line it may not work dure to some proprietary configuration.
