Simple Routing Question
Chris Snape
Hi all,
I have a Cisco 1841 serving as a connection between my ISP and my Firewall (non Cisco).
I seem to be having performance issues with my traffic going through the Router.
HTTP (web browsing) is fine andI get my download rate as I would expect for a 10mbps connection.
But anything to do with my VPNs I find a delay when sending via the 1841.
(all my VPNs are managed by my Firewall and I have never had problems with those).
I also have a legacy ADSL connection to my firewall, which bypasses the 1841 and I am having no issues on that at all.
If anything it is quicker! Which is madness as my Fibre should out-perform it easily.
This leads me to believe the issue is not with the Firewall.
My 1841 is very simply setup, 2 fa interfaces with simply a default gateway setup within it.
Which leads me to ask if I need more static routes in or a dynamic route protocol setup?
Snippet of Config:
ip cef
no ip domain lookup
ip name-server 158.152.1.43
ip name-server 158.152.1.58
no ipv6 cef
license udi pid CISCO1841 sn FHK122122XS
archive
log config
  hidekeys
redundancy
interface FastEthernet0/0
ip address 1.1.1.1 255.255.255.252
duplex auto
speed auto
interface FastEthernet0/1
ip address 2.2.2.2 255.255.255.248
duplex auto
speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 1.1.1.1
What else do I need to speed it up?
Chris Snape
gaurav bhardwaj
default route should be to asa
that is ip route 0.0.0.0 0.0.0.0 (asa interface ip address which is connect to router)
then pass to router
you give the default route to router interface,,,and it should be the next hop ip
like if you asa e0/0 connect to the router and the ip address 1.1.1.2 255.255.255.242
then the commend is
ip route 0.0.0.0 0.0.0.0 1.1.1.2
hope it's help you
Thanks for the reply.
Just to clarify my firewall is inside the Cisco 1841.
ISP << 1841 << Firewall << LAN
All I want the 1841 to do it route from one to the other, nothing else.
How about connecting the FW directly to the ISP (don't use the backup DSL).
Does the VPN connection from the FW improves?
If Web Browsing via the 1841 is using full speeds, I don't see anything in your configuration
preventing encrypted data from going full speeds.
first of all i just want too say you should  deploy you asa after isp and then you can provide batter security if you take this topology  you have to maintain so many acl ..buy any way now the scenario is defferent
ok
