08-15-2006 05:17 PM - edited 03-03-2019 01:40 PM
I have read that :
"If router interfaces are configured in sparse mode only, a static RP address must also configured".
Can anyone recommend a document that authentiacte above ?
08-15-2006 05:46 PM
Cisco's newer version also allows you to have the Auto-RP feature, please read this URL
Please rate helpful posts.
08-16-2006 01:08 AM
Could you please post the link again
08-16-2006 05:07 AM
Oops, sorry about that:
http://www.cisco.com/en/US/tech/tk828/technologies_white_paper09186a00800d6b63.shtml
08-16-2006 10:19 AM
Auto-RP would actually require sparse-dense-mode if no static RP configured, wouldn't it?. But BSR feature could work even with sparse-mode.
08-16-2006 03:31 PM
Correct.
08-16-2006 06:17 AM
This is not absolutely true. you can configure sparse-mode and still run dynamically learned RP (Auto-RP).
This was made possible by the introduction of the global command "ip pim autorp listener" it allows you to run auto-rp with sparse-mode.
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124cr/himc_r/mlt_i2h.htm#wp1068637
