12-12-2006 05:39 PM - edited 03-03-2019 03:01 PM
Sorry,learning here..
Would like to know how can I setup a 2M link from one router to another ? I have 2 WAN IPs addresses with me now.
Any steps/precautions i need to take care for this setup?
thanks.
Solved! Go to Solution.
12-12-2006 10:06 PM
I suggest to get the sample config. of the router's WAN connection from the ISP.
If it is a serail interface only, you only need to configure the correct encapsulation mode, IP address and no shut the interface. However, you also need to configure corresponding routing protocol to make your local traffic to talk to the Internet.
Hope this helps.
12-12-2006 06:54 PM
You need to talk to the local ISP.. u will require one router and one modem (optional) at each end to get the 2 M link operational.. I guess the local DOT guys will be the right one to help you. Once you get the physical circuit up, u can assign IP addresses to each end and start routing packets..
hope this helps.. all the best..
Raj
12-12-2006 10:06 PM
Hope this helps.
12-13-2006 12:47 AM
Thanks Jack..
Will try out you guys advise once the leased line is setup..:D
Will rate you guys post..
12-13-2006 11:56 AM
Hi Jack - I have the same scenario and I have setup everything as you suggested, but the problem is that I can't get to the internet - I can ping the isp from the router IOS but I can't do it from my computer.
12-13-2006 10:23 PM
Hi Damb,
since u say that u can ping from the router & not from the PC, u may have to do NAT on the router to translate ur computers private ip address to public IP address then only it is possbile. ur ISP would have given some public IP address with that u can do NAT with the the sample configuration below.
assume that serial interface has public IP & fastethernet has got private IP.
2.2.2.x set of IP addresses will be given by ur ISP
interface serial 0
description ***Connected to Internet***
ip address 1.1.1.1 255.255.255.252
ip nat outside
interface fastethernet 0
description ***Connected to LAN***
ip address 10.1.1.1 255.255.255.0
ip nat inside
ip nat translation timeout 3600
ip nat pool TEST 2.2.2.1 2.2.2.10 netmask 255.255.255.240
ip nat inside source list 1 pool TEST overload
ip classless
ip route 0.0.0.0 0.0.0.0 serial 0
it works perfectly with no doubt on this.
rate this post if cleared.
12-13-2006 11:35 PM
Emmanuel, agreed w/ Anand that if your router is a new one w/o proper configuration. You have to enable a series of feature to make it work w/ Internet.
The general idea is to make the direct connection (i.e. serial interface) works (i.e. can ping from router to remote), then enable the routing protocol (e.g. enable default route, "ip route 0.0.0.0 0.0.0.0 serail 0"), then enable the Network Address Tanslation (e.g. those "nat" commmands) in the router.
I suggest to get a sample config. from the ISP, or the reseller who sell the Internet and router service to you.
Check below for the sample config. and info.
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a0080094e77.shtml
And the other issue is to confirm your PC can ping to the router LAN interface then ping to WAN interface. If you cannot ping to LAN interface, it means the PC and the router are not in the same segment; if PC cannot ping to the WAN interface, it means the routing protocol or the default gateway of your PC is not configured properly.
Or please provide your existing config. then we can help to troubleshoot it.
Hope this helps.
12-14-2006 06:37 AM
Hi Jack
Thanks a Lot for your help, you can find attached the running config - the problem is that the PC was setup with a static IP address along the subnet 172.0.0.1/24 and it is using the gateway 172.0.0.1, from the PC I can ping the router WAN IP XXX.XX.XXX.X6 and I can also Ping the Gateway 172.0.0.1 for the Fastethernet0 - but I can't ping the public gateway from the PC - I am using the gateway of the ISP XXX.XX.XXX.X5 as the Default router Gateway - From the Router IOS - I can ping any public IP's and Local IP's on the subnet. you can see that NAT was enabled by default since I tunred off IP routing.
12-14-2006 06:45 AM
It seems NAT is not properly configured.
can you try out these changes on your router.
interface FastEthernet0
ip nat inside
interface Serial0
ip nat outside
no ip default-gateway XXX.XX.XXX.X5
ip route 0.0.0.0 0.0.0.0 s0
no ip nat inside source static 172.0.0.1 XXX.XX.XXX.X6
access-list 7 172.0.0.0 0.0.0.255
ip nat inside source list 7 interface serial 0 overload
12-15-2006 04:14 PM
Hi Sour
It worked with this settings but I had to enable the gateway before it worked - thanks a lot for your assistance and thanks to Jack and Anand
12-16-2006 07:21 AM
You're welcome. It is great you solved it. ;)
12-14-2006 07:29 AM
Hi Cindy,
Just to add little icing over here. Just wondering if you have sorted out everything at the L-2 Side (I mean WAN Interface).
Generally depending upon the location you may be offered the following Link types:-
1. E-1 Link
2. T-1 Link
3. J-1 et. al Link (which is more localized favor of T-1 Links)
Now, E-1 (2.04b Mbps) and T-1 (1.544 Mbps) could be either Channelized or a simple E-1 or T-1.
If you want to terminate the T-1 / E-1 Line directly into the Router you need to go ahead with MFT VWICs as mentioned in the link:
http://www.cisco.com/en/US/products/hw/modules/ps3129/prod_module_series_home.html
Depending upon the requirment you may go ahead and configure a combination of Voice / Data channels of DS-0s (or multiples of 64kbps).
You may take help from the following link for the configuration of the VWIC MFT cards.
http://www.cisco.com/en/US/products/hw/routers/ps221/prod_configuration_guide09186a00800a4063.html
HTH,
Please rate if it helps
Wilson Samuel
