Verify traffic is routed with OSPF when running multiple routing protocols
hmc2500
Hi is there a way you can verify that traffic is routing with OSPF when you are running multiple routing protocols (say EIGRP) on a L3 switch or router? Both protocols show the same routes but I would like to verify that data is routed with OSPF before removing EIGRP.
Harold Ritter
The way to verify that, is to check which protocol is the source of the route in the RIB.
Harold Ritter
balaji.bandi
Check the routing table and OSPF Database.
BB
Hello
you can always increase the eigrp admin distance in all the eigrp routing process before you remove it.so its higher than ospf 110
router eigrp xx
distance eigrp 170 210
Kind Regards
Paul
