WS-C4507R-E
husseinmuneer
I have the following items :
SN
P/N
Description
Qty
WS-C4507R-E
Cat4500 E-Server 7-Solt chassis, fan,   no ps, Red Sup Capable
PWR-C45-4200ACV
Catalyst 4500 4200W AC dual input   power  Supply (Data+PoE)
WS-X4548-GB-RJ45
Catalyst 4500 Enhanced 48- port   PoE+Ready 10/100/1000
WS-X4306-GB
Catalyst 4500 Gigabit Ethernet   Module, 6ports(GBIC)
X2-10GB-SR
10GBase-SR X2 Module
They can work without the  Supervisor Engine or I must install it ?
If I must install the Supervisor Engine what is the P/N for the card which is compatible with C4507R-E ?
2 Accepted Solutions
lgijssel
Level 9
Level 9
spremkumar
Level 9
Level 9
hi muneer
you need to have one sup and can go for 2 sups if you are particular about supervisor redundancy.
you can check out the details about the supervisors under the below link.
http://www.cisco.com/en/US/products/hw/switches/ps4324/products_relevant_interfaces_and_modules.html
regds
5 Replies 5
lgijssel
Level 9
Level 9
You can order the SUP6:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps4324/product_bulletin_c25-530835.html
partnr: WS-X45-SUP6L-E
ios: S45EIPBK9-12253SG
regards,
Leo
spremkumar
Level 9
Level 9
hi muneer
regds
I got it .
Can the switch work without the supervisor engine card at least with the basic operation for example L2 functions. because we should use it now then we will buy the WS-X45-SUP6L-E card.
No it can't work without A supervisor card.
