Help Needed with VRRP Failover on WAN Side Using Cisco vManage SD-WAN
banoosh
Hi Cisco Community,
We’ve set up VRRP on the LAN side successfully, but we’re facing issues with the WAN side while using Cisco vManage SD-WAN. The failover isn't working as expected from the WAN side, and we’re not sure what could be causing this issue.
Has anyone experienced a similar problem or can provide insights on troubleshooting VRRP failover issues on the WAN side in a Cisco SD-WAN environment? Any advice or guidance would be greatly appreciated!
Thank you in advance!
balaji.bandi
We need more information and topology how that was configured and connected.
If you deployed correctly you do not need VRRP for the SD-WAN Lan side, depends on the IGP you using should able to meet the requirement, why are we suing VRRP here, what is the requirement ?
check the configuration guide :
https://www.cisco.com/c/en/us/td/docs/routers/sdwan/configuration/system-interface/vedge-20-x/systems-interfaces-book/m-vrrp-tracking.html
https://www.youtube.com/watch?v=WrNfvmrV4-8
BB
This session introduces the you to Cisco SD-WAN TLOC extension feature that can be used to configure transport redundancy for those branch sites where full mesh transport connectivity is not feasible and/or cost prohibited. We begin with a brief description of the TLOC extension feature, followed
in the basic form you need to track OMP. So, if WAN fails but LAN is running, then failover occurs.
Plus, there is tloc-change feature which makes symmetric traffic flow from lan <> wan with respect to site VRRP router
 vrrp 1 address-family ipv4
vrrpv2
address a.b.c.d
priority XX
track omp decrement 20 > this means that, if router loses all OMP sessions, it decrements priority, so secondary router takes the master role
tloc-change increase-preference 10 > this means that, if router is master in LAN it increases WAN interfaces' TLOC preference +10, so inbound traffic from overlay come to master router, purpose is to keep symmetricy
HTH,
I’m reaching out for some insights regarding the holdtime configuration for OMP. We’re considering setting the holdtime to 0 and would like to understand the potential impact on both the site and WAN side.
Could someone clarify what it means to set the holdtime to 0 instead of a specific number? Additionally, are there any known implications for stability or connectivity when the holdtime is set to 0?
Any advice or experiences would be greatly appreciated
