Bookmark
Subscribe
1499
Onboarding vEdge issue
mohamedyare
Please bear with me if my questions seem basic, as I'm just starting to delve into this subject. I've successfully configured vManage, vBond, and vSmart. Currently, I'm in the process of onboarding the vEdge router, but I'm encountering an issue where the WAN Edge routers aren't appearing as registered.
I installed CARoot certificate on the vedge router and also activated vedge-cloud chassis number and token, under connection seems connection is stablished , however it seems DTLS overlay has not been setup.
some of show output are attached.
balaji.bandi
Is the vEDGE is behind NAT or FW ? do you have enough ports open to establish connection
check some ports requirement
https://www.cisco.com/c/dam/en/us/td/docs/solutions/CVD/SDWAN/sdwan-wan-edge-onboarding-deploy-guide-2020nov.pdf
BB
Thank you for your prompt replay Balaji.
I follow configuration steps and still getting DCONFAIL which is DTLS error
"show control local-properties" clearly shows that your device does not have certificate for it.
Which certificate option did you choose for virtual devices from vmanage administration settings? If it is enterprise CA, you need to generate CSR and sign it with rootCA.
HTH,
A CSR was generated from the vEdge router, assigned by the CA, and then uploaded the Identity Certificate back to the vEdge router; however, the status of the connection is showing 'teardown'.
Secondly, on the WAN Edge List, it displays a red cross for the status of the vEdge cloud.
it also showns that vEdge cloud device is required a device license:
If that is the issue, is there any way I can set up an SD-WAN lab without purchasing a license subscription?
