Transport Gateway error
donald.heslop1
I running into an issue with Catalyst SD-WAN went trying to push a simple template to a devices. I keep getting the following error no matter what I adjust in the system template:
[7-May-2024 21:50:51 UTC] Configuring device with feature template: c8000v_branch_template
[7-May-2024 21:50:52 UTC] Checking and creating device in vManage
[7-May-2024 21:50:53 UTC] Generating configuration from template
[7-May-2024 21:51:01 UTC] Device is online
[7-May-2024 21:51:02 UTC] Updating device configuration in vManage
[7-May-2024 21:51:02 UTC] Sending configuration to device
[7-May-2024 21:51:12 UTC] Device failed to process request. Error Path -
/rpc/edit-config/config/viptela-system:system
An element value is not correct : transport-gateway.
I've looked at the system template and I've turned the transport-gateway setting off and on and that has not changed anything. Does anyone known what this error is about?
donald.heslop1
This issue has been resolved. The problem was the C8000v image. Once I changed the image to 17.13.01a the configuration push was successful.
balaji.bandi
What version of SD-WAN controller, what version of v8K
is this real or Lab environment ?  is this only one device template having issue ?
check below thread :
https://community.cisco.com/t5/sd-wan-and-cloud-networking/template-push-error-an-element-value-is-not-correct-is-vmanaged/td-p/4813254
Can you download device template and have a look on the file.
BB
The SD-WAN controller is 20.13.1 and the version of 8K is 17.5.1a. Its a lab environment and it happens when I push a device template to the C8K. I have a vSmart template and it works fine when I pushed it to the two vSmart controllers.
donald.heslop1
