05-07-2024 03:03 PM
I running into an issue with Catalyst SD-WAN went trying to push a simple template to a devices. I keep getting the following error no matter what I adjust in the system template:
[7-May-2024 21:50:51 UTC] Configuring device with feature template: c8000v_branch_template
[7-May-2024 21:50:52 UTC] Checking and creating device in vManage
[7-May-2024 21:50:53 UTC] Generating configuration from template
[7-May-2024 21:51:01 UTC] Device is online
[7-May-2024 21:51:02 UTC] Updating device configuration in vManage
[7-May-2024 21:51:02 UTC] Sending configuration to device
[7-May-2024 21:51:12 UTC] Device failed to process request. Error Path -
/rpc/edit-config/config/viptela-system:system
An element value is not correct : transport-gateway.
I've looked at the system template and I've turned the transport-gateway setting off and on and that has not changed anything. Does anyone known what this error is about?
Solved! Go to Solution.
05-08-2024 06:21 AM
This issue has been resolved. The problem was the C8000v image. Once I changed the image to 17.13.01a the configuration push was successful.
05-07-2024 10:36 PM
What version of SD-WAN controller, what version of v8K
is this real or Lab environment ? is this only one device template having issue ?
check below thread :
Can you download device template and have a look on the file.
05-08-2024 04:46 AM
The SD-WAN controller is 20.13.1 and the version of 8K is 17.5.1a. Its a lab environment and it happens when I push a device template to the C8K. I have a vSmart template and it works fine when I pushed it to the two vSmart controllers.
05-08-2024 06:21 AM
