vManage can not push the template to WAN Edge Device
dungnt
Hi everyone,
I have built the controller on-prem for lab. In the ver 20.3 everything is ok but when I upgrade vManage to 20.6, I can not push the template to WAN Edge Device, the error code is below:
Server error: no registration found for callpoint vmanage-bfd-servicepoint/service_create of type=external
At first I think this is because the version 20.6 but when I upgrade to 20.6 it dont solve the problem. Anyone can help pls?
6 Replies 6
dungnt
manuelosorio
Hi @dungnt
I think 20.6.1.1 have a bug.  Something similar happened to this colleague.
https://community.cisco.com/t5/sd-wan-and-cloud-networking/server-error-no-registration-found-for-callpoint-vmanage-bfd/td-p/4484505
Do you have which version  20.6.1.1 or 20.6.3?
The version suggested by cisco is the 20.6.3.
Thanks @manuelosorio
At first I upgrade from 20.3.5 to 20.6.3 and the error happened. I think it might be the bug of 20.6 then I continue to upgrade to 20.8.1, the error is still happened. I dont know if it is because the version of vManage or sth else
fcbob2007
Hi ,
20.6.3 got some bug where we were facing issue too.
Raise a TAC case and they can provide u a temporary patch which will fix your issue. We have testing this today with the support of TAC engineer.
Cisco is yet to release new version 20.6.3.1 probably by end of this month.
fcbob1
Cisco released 20.6.3.1 version to mitigate this bug issue. Also they have made it Starred Release.
We have tested this in our lab and can confirm that it does fix the issue. Just upgrade the vManage, re-push the device template and all sorted.
Hello.
Is there another solution ?
I'm suffering this problem.
vManage : 20.9.4.1
vBond, vSmart : 20.9.4
C8000v : 17.9.4a
I dont know why this problem happens only in C8000v (Not occured in vEdge Cloud)
