ACE in bridge-mode need static IP routes?
lacirasella
i'm trying to configure FIREWALL load-balancing via ACE in L2 mode, and
there is something i don't understand.
"client 1" ping "client 2", trace shows
- the ping crossing MSFC
- arriving on ACE via VLAN 10
- existing via ACE VLAN 11
- ping reach the FW1 on vlan 11 and exit FW1 on VLAN 21
- finally we see the ping on ACE on VLAN 21 but never exit on VLAN 20
     client 1
     MSFC 1
         |              VLAN 10
       ACE
     ------------       VLAN 11
FW1      FW2
     ------------       VLAN 21
      ACE
         |              VLAN 20
     MSFC 2
    client 2
unless i set a "IP route"  on ACE to reach the destination subnet (client 2) to MSFC 2
the ping doesn't work.
At this point, what i don't understand is why i have to put an IP route in bridge mode?
i try specificaly this ACE configuration mode to not set all the IP route in L3 mode!!!
Do someone see where i'm wrong?
Last point, here is what the service-policy apply to VLAN 21 shows when the route doesn't exist:
LAB-DC1-CE-PE1-ACE/C1# sh service-policy PM-L4-R-STICKY-FW-B det
Status     : ACTIVE
Description: -----------------------------------------
Interface: vlan 21
  service-policy: PM-L4-R-STICKY-FW-B
    class: CM-VIP-BGP-B
     VIP Address:    Protocol:  Port:
     0.0.0.0         tcp        eq    179
      loadbalance:
        L7 loadbalance policy: PM-L7-R-STICKY-FW-B-BGP
        VIP Route Metric     : 77
        VIP Route Advertise  : DISABLED
        VIP ICMP Reply       : DISABLED
        VIP State: INSERVICE
        curr conns       : 0         , hit count        : 4
        dropped conns    : 4
        client pkt count : 4         , client byte count: 176
        server pkt count : 0         , server byte count: 0
        conn-rate-limit      : 0         , drop-count : 0
        bandwidth-rate-limit : 0         , drop-count : 0
        L7 Loadbalance policy : PM-L7-R-STICKY-FW-B-BGP
          class/match : class-default
            LB action :
               forward
               reverse sticky group: BOTH_IP_STICKY_B_BGP
                  primary serverfarm: SF-FW-B-BGP
                    state: UP
                  backup serverfarm : -
            hit count        : 4
            dropped conns    : 0
    class: CM-VIP-DEFAULT-B
     0.0.0.0         any
      loadbalance:
        curr conns       : 0         , hit count      : 2
        dropped conns  : 2
        client pkt count : 2         , client byte count: 200
            LB action :
               forward
                    state: UP
            hit count        : 2
            dropped conns    : 0
7 Replies 7
robert.horrigan
Level 2
Level 2
What is the default gateway of your rservers?
hi?
i'm actually pointing to the fws
i also try try to point to the ACE alias but the result is worst
Maurice
Can you try by enabling 'mac-sticky' under vlan interface.
This link explains Firewall Loadbalancing along with sample config,
http://docwiki.cisco.com/wiki/Cisco_Application_Control_Engine_%28ACE%29_Configuration_Examples_--_Server_Load-Balancing_Configuration_Examples#Examples_of_Firewall_Load-Balancing_Configurations
Try enabling 'mac-sticky' and let me know if that helps.
Best Regards,
Rahul
that is already done on vlan toward the firewall
i also try to install it on vlan toward the client
the problem is still here
Did you try configuring mac-sticky towards client vlan, did it help. If not then you may want to open TAC case to troubleshoot.
Best Regards,
Rahul
same result,
a SR is open on the TAC
A Cisco guys at CiscoLive in London told me that IP route are mandatory now in L2 mode, which mean
that is was not the case in the first release of the ACE (i have also test it in an old release and it was
working without any routes).
I'm waiting for the TAC answer.
Thanks for your help
confirmation that ACE in L2 mode need IP routes
it was always the case
Maurice
