compare CIP with Token Ring
mjwo
2600----7507--cip-------------------MainFrame
(dlsw)----TokenRing----3745 --------
Suppose, when remote SNA device want to connect to mainframe through DLSW, CIP reponse should be faster than TokenRing right?? But we found most cir go through TokenRing!! Should we need to tuning MainFrame configuration??
Jwo
12 Replies 12
emazurek
Your network diagram wasn't very clear. Are you
saying that the remote DLSw peer(where the device is
at) connects to two data center DLSw peers where one
is a CIP and the other is an IBM FEP? Please clarify
your diagram.
But, normally, the circuit will be given to the first
device(CIP or FEP) that responds to the Test poll.
This shouldn't have anything to do with the mainframe
because te CIP responds to the Test poll locally.
That is, it responds to the test without the
mainframe.
You need to verify that the XCA major node that
activates the CIP has enough lines/PUs defined so
that it can accept more incoming connections. Also,
you could check to see how loaded the CPUs are in
both the 7507 and the CIP. You get that information
via the show process cpu command(for the router) and
the show controller cbus command(for the CIP).
If you want to force the connections to the CIP then
you can specify a lower cost in the DLSw remote-peer
command(assuming you do have multiple remote peers.
When you do this you will also need to specify dlsw
timer explorer-wait-time 3. Both of these are
specified in the remote side.
Please give me more information such as a network
diagram, dlsw configs from the routers involved,
sho dlsw peer and show dlsw circuit and I'll be glad
to continue to assist.
Ed Mazurek
here is centrol router and remote router configuration.
centrol router:
source-bridge ring-group 100
source-bridge transparent 100 13 1 1
dlsw local-peer peer-id 10.1.253.235 promiscuous
dlsw icanreach sap 0 4 8
dlsw bridge-group 1
interface Loopback0
ip address 10.1.253.235 255.255.255.255
interface Channel1/0
description connect to production
no ip address
no keepalive
csna 0110 01
csna 0110 00
interface Channel1/2
ip address 10.1.98.1 255.255.255.0
no keepalive
max-llc2-sessions 6000
lan TokenRing 1
source-bridge 98 1 100
adapter 2 4000.3745.0001
name cxp401
adapter 3 4000.3745.0008
name cxp400
interface FastEthernet4/0/0
ip address 10.1.99.235 255.255.255.0
bridge-group 1
interface TokenRing6/0/0
description connect to NCP
no ip address
early-token-release
ring-speed 16
bridge-group 1
source-bridge 9 1 100
source-bridge spanning
remote router configuration:
source-bridge ring-group 2000
dlsw local-peer peer-id 10.1.253.39
dlsw remote-peer 0 tcp 10.1.253.235
dlsw icanreach sap 4 8
interface Loopback0
ip address 10.1.253.39 255.255.255.255
interface Serial0/1
description Connect to MSD of AT&T /w 6 ports
no ip address
encapsulation sdlc
no ip mroute-cache
no keepalive
nrzi-encoding
clockrate 9600
sdlc role primary
sdlc vmac 4000.2610.3900
sdlc address A2
sdlc xid A2 01703911
sdlc partner 4000.3745.0001 A2
sdlc address B1
sdlc xid B1 01703921
sdlc partner 4000.3745.0001 B1
sdlc address C3
sdlc xid C3 01703901
sdlc partner 4000.3745.0008 C3
sdlc dlsw A2 B1 C3
Jwo
jishi
The reason the most circuits go through Tokenring is because the explorers from TokenRing side get back to the remote dlsw router faster than the explorer from CIP side. That means you mostly likely have a faster WAN connection between remote dlsw router and the the TokenRing side. If you prefer the CIP, you have to config "explorer-wait-time" and give lower dlsw peer cost to the CIP side.
Here is link for controlling dlsw peer selection:
http://www.cisco.com/en/US/tech/tk331/tk336/technologies_design_guide09186a0080237a5e.shtml#wp16269
Jing
Thank you for your reply!!
TokenRing and CIP are in the same 7507 router.Remote dlsw connect to the 7507 router, then go through CIP or TokenRing to Host.
Bus as I know, CIP speed should be faster than TokenRing. Why the explorers from TokenRing side get back to the remote dlsw router faster than CIP side??
Should we need to tuning Host configuration??
Jwo
I don't think you can tune the host config since the explorer is answered by the vtok adaptor or the NCP. The reason CIP reponses slower than tokenring is because the NCP is on the physical ring, NCP response it immediately, no software processing in between. But for the CIP, it goes the vtok adaptor, and involves software processing, so the explorer gets back little bit slower.
If you use seperate virtual ring group for CIP and the tokenring, and create a virtual-tokenring interface, bridge into the virtual ring which the tokenring is bridged into, you might be able to use "dlsw ring-list" to restrict the ring number only from the virtual ring which the CIP is bridged into and the ring number which the virtual-tokenring interface is on.
Basically you are adding a virtual ring and a bridge between the NCP and the router, hope it will slow down the explorer coming from the NCP.
Jing
There is a parameter on the NCP to delay the response to the explorer. You can modify that.
What's the parameter on the NCP to delay the response to the explorer???
Jwo
What exact model of NCP you have? It should be in the line defination.
Sorry for the confusion. I was trying to say the delay parameter is in the line defination.
Please take a look at the following link for the "balance" parameter.
http://publibfp.boulder.ibm.com/cgi-bin/bookmgr/BOOKS/cxdg7009/2.3.2.2?ACTION=MATCHES&REQUEST=auto+balance&TYPE=FUZZY&SHELF=&DT=20000620173822&CASE=&searchTopic=TOPIC&searchText=TEXT&searchIndex=INDEX&rank=RANK&ScrollTOP=FIRSTHIT#FIRSTHIT
http://publibfp.boulder.ibm.com/cgi-bin/bookmgr/BOOKS/cxdh1009/2.23.15?DT=20000531143225#SPTGBAL
If you set the factor to 1, the TIC might delay sending a response to the explorer.
Jing
emazurek
Hi Jwo,
As I indicated before there is really nothing to
configure in the CIP to allow it to respond quicker
than the TR attached FEP.
One thing I noticed in your config that doesn't look
right is that at the central site router you have a
combination of transparent, translational and
source-route bring configured. I doubt you need all of those and it could be affecting you.
You have "bridge-group 1" configured under the
TR 6/0/0 interface. Do you know why you have that?
Since you already have SRB
configured(source-bridge...) you generally don't
need that. What that does is configure transparent
bridging under the TR interface. Since you already
have the TR interface bridged into the Fa4/0/0 via
the "source-bridge transparent 100 13 1 1" command
you don't need that.
Also, are there devices on the Fa4/0/0 interface
that need to be bridged into the CIP and/or TR 6/0/0
interface? If there aren't any then you can remove
as well. Be careful here though, you may need it.
Finally, you can configure "dlsw load-balance" at
the central site router to cause DLSw to load
balance between the available local paths. This
should cause an approximate 50/50 balance between
the FEP and the CIP.
Please let me know.
Ed Mazurek
Hi Ed,
There are SNA gateway and AS400 in on the Fa4/0/0 and need to be bridged into CIP or TR6/0/0 interface.
So we need translation bridge. By the way, I am not sure why has "bridge-group 1" configured under the TR 6/0/0, I would remove it and try.
Very thanks for your help!!
Jwo
rsissons
Level 5
Level 5
I guess it depends how heavily loaded the total path via the CIP is as compared to the path via the token ring and the FEP since the session will always be established via the first to respond. I am not aware of any parameters that are available on the mainframe to delay the reponse however.
