07-20-2011 08:48 AM
Hello
We have a nexus 2000 connecto to two nexus 7010 as FEX.
I see this in first nexus
nexus-1(config)# sh fex
FEX FEX FEX FEX
Number Description State Model Serial
101 FEX0101 Online N2K-C2248TP-1GE JAF1437BRCA
but on nexus-2 i see same nexus offline
nexus-2(config)# sh fex
FEX FEX FEX FEX
--- -------- Offline N2K-C2248TP-1GE JAF1437BRCA
I try to insert fex portchannel on vPC domani ( alredy active for network vpc) but i recive that error:
nexus-2(config)# interface port-channel 100
nexus-2(config-if)# vpc 100
ERROR: Error in performing configuration: Unsupported option for sap 167
in vpc I see:
sh vpc
Legend:
(*) - local vPC is down, forwarding via vPC peer-link
vPC domain id : 1
Peer status : peer adjacency formed ok
vPC keep-alive status : peer is alive
Configuration consistency status: success
Type-2 consistency status : success
vPC role : primary
Number of vPCs configured : 2
Peer Gateway : Disabled
Dual-active excluded VLANs : -
vPC Peer-link status
id Port Status Active vlans
1 Po1 up 1
vPC status
id Port Status Consistency Reason Active vlans
10 Po10 up success success 1
100 Po100 down* Not Consistency Check Not -
Applicable Performed
anyone can help me?
Ty
Solved! Go to Solution.
07-20-2011 10:37 AM
07-20-2011 10:37 AM
It is not supported in the current release.
jerry
07-21-2011 04:10 AM
ty soo much.
You know if this feature can be available on the next 5.2 relase?
07-21-2011 07:47 AM
Not that I am aware of. Short answer will be a "no".
jerry
11-10-2011 11:18 PM
In which release, this feature will be supported?
11-11-2011 06:14 AM
Nothing i m aware of.
jerry
01-31-2013 01:08 AM
Hi, is this feature suppored in 6.1 release?
01-31-2013 07:32 PM
No, it is not supported in 6.1.
06-04-2015 06:33 AM
We tested this in our lab and it is possible. You have to make sure your 7K is licensed for it and you enable the FEX Feature set on the 7K
