Nexus 5k vfc won't come up
pcashaback
I have a n5k already configured with a fiber san and esx host running cna's.  I'm trying to add another and I just can't get the vfc to come up.  I've posted my config and a couple sho's that I've found through other discussions....
DataSw2#  sho run
version 4.1(3)N1(1)
fctimer distribute
feature fcoe
feature npiv
feature telnet
feature fcsp
feature udld
feature vpc
feature fex
ip host DataSw2 192.168.5.93
switchname DataSw2
ntp server 192.168.5.1 use-vrf management
vrf context management
  ip route 0.0.0.0/0 192.168.5.254
vlan 1
vlan 180
  fcoe vsan 18
vlan 190
  fcoe vsan 19
vsan database
  vsan 18 name "AX4"
fcdomain fcid database
  vsan 1 wwn 50:06:01:61:44:60:1e:62 fcid 0x7000ef dynamic
  vsan 1 wwn 50:06:01:69:44:60:1e:62 fcid 0x7001ef dynamic
  vsan 1 wwn 20:02:00:0e:11:13:97:b2 fcid 0x700000 dynamic
  vsan 18 wwn 21:00:00:c0:dd:14:8d:f7 fcid 0xea0001 dynamic
  vsan 18 wwn 21:00:00:c0:dd:14:8e:3f fcid 0xea0002 dynamic
  vsan 18 wwn 21:00:00:c0:dd:14:8e:33 fcid 0xea0003 dynamic
  vsan 18 wwn 50:06:01:61:44:60:1e:62 fcid 0xea00ef dynamic
  vsan 18 wwn 50:06:01:69:44:60:1e:62 fcid 0xea01ef dynamic
  vsan 18 wwn 20:05:00:0e:11:13:97:b2 fcid 0xea0000 dynamic
interface vfc9
  bind interface Ethernet1/9
  no shutdown
interface vfc11
  bind interface Ethernet1/11
  no shutdown
interface vfc13
  bind interface Ethernet1/13
  no shutdown
interface vfc15
  bind interface Ethernet1/15
  no shutdown
interface vfc16
  bind interface Ethernet1/16
  no shutdown
vsan database
  vsan 18 interface vfc9
  vsan 18 interface vfc11
  vsan 18 interface vfc13
  vsan 18 interface vfc15
  vsan 18 interface vfc16
  vsan 18 interface fc2/1
  vsan 18 interface fc2/2
  vsan 18 interface fc2/5
interface fc2/1
  no shutdown
interface fc2/2
  no shutdown
interface fc2/3
  no shutdown
interface fc2/4
interface fc2/5
  no shutdown
interface fc2/6
interface fc2/7
interface fc2/8
interface Ethernet1/2
interface Ethernet1/3
interface Ethernet1/4
interface Ethernet1/5
interface Ethernet1/6
interface Ethernet1/7
interface Ethernet1/8
  switchport mode trunk
interface Ethernet1/10
interface Ethernet1/12
interface Ethernet1/14
  switchport trunk allowed vlan 1,180
  spanning-tree port type edge trunk
interface Ethernet1/17
interface Ethernet1/18
interface Ethernet1/19
interface Ethernet1/20
interface mgmt0
  ip address 192.168.5.93/24
line console
boot kickstart bootflash:/n5000-uk9-kickstart.4.1.3.N1.1.bin
boot system bootflash:/n5000-uk9.4.1.3.N1.1.bin
cfs ipv4 distribute
cfs eth distribute
interface fc2/1
interface fc2/2
interface fc2/3
interface fc2/4
interface fc2/5
interface fc2/6
interface fc2/7
interface fc2/8
vsan 18 is already up with 3 hosts, I'm trying to add a 4th.  The port in question is eth 1/15, vfc 15.  Status oper is down
#sho lldp nei
Remote Peers Information on interface Eth1/15
Remote peer's MSAP: length 12 Bytes:
00    c0    dd    11    33    26    00    c0    dd    11    33    26
LLDP TLV's
LLDP TLV type:Chassis ID  LLDP TLV Length: 7
LLDP TLV type:Port ID  LLDP TLV Length: 7
LLDP TLV type:Time to Live  LLDP TLV Length: 2
LLDP TLV type:LLDP Organizationally Specific  LLDP TLV Length: 61
LLDP TLV type:END of LLDPDU  LLDP TLV Length: 0
#sho int vfc 15
vfc15 is down
    Bound interface is Ethernet1/15
    FCF priority is 128
    Hardware is Virtual Fibre Channel
    Port WWN is 20:0e:00:0d:ec:ef:38:ff
    Admin port mode is F, trunk mode is on
    snmp link state traps are enabled
    Port vsan is 18
    1 minute input rate 0 bits/sec, 0 bytes/sec, 0 frames/sec
    1 minute output rate 0 bits/sec, 0 bytes/sec, 0 frames/sec
      0 frames input, 0 bytes
        0 discards, 0 errors
      0 frames output, 0 bytes
Any ideas?
Thanks!
Prashanth Krishnappa
Configuration wise, I do not see anything standing out. A vFC will not come up until the host associated with it sends out a FLOGI frame. Make sure your CNA has the appropriate FCOE drivers and is initiating FLOGI. Also  make sure the CNA supports the media type you are using.
Lucien Avramov
Level 10
Level 10
Make sure your vlan is in the vlan database and the vsan is in the vsan database.
If you have a qlogic qle 8152, then you need a twinax cable.
