10-21-2010 11:08 AM
I have a n5k already configured with a fiber san and esx host running cna's. I'm trying to add another and I just can't get the vfc to come up. I've posted my config and a couple sho's that I've found through other discussions....
DataSw2# sho run
version 4.1(3)N1(1)
fctimer distribute
feature fcoe
feature npiv
feature telnet
feature fcsp
feature udld
feature vpc
feature fex
ip host DataSw2 192.168.5.93
switchname DataSw2
ntp server 192.168.5.1 use-vrf management
vrf context management
ip route 0.0.0.0/0 192.168.5.254
vlan 1
vlan 180
fcoe vsan 18
vlan 190
fcoe vsan 19
vsan database
vsan 18 name "AX4"
fcdomain fcid database
vsan 1 wwn 50:06:01:61:44:60:1e:62 fcid 0x7000ef dynamic
vsan 1 wwn 50:06:01:69:44:60:1e:62 fcid 0x7001ef dynamic
vsan 1 wwn 20:02:00:0e:11:13:97:b2 fcid 0x700000 dynamic
vsan 18 wwn 21:00:00:c0:dd:14:8d:f7 fcid 0xea0001 dynamic
vsan 18 wwn 21:00:00:c0:dd:14:8e:3f fcid 0xea0002 dynamic
vsan 18 wwn 21:00:00:c0:dd:14:8e:33 fcid 0xea0003 dynamic
vsan 18 wwn 50:06:01:61:44:60:1e:62 fcid 0xea00ef dynamic
vsan 18 wwn 50:06:01:69:44:60:1e:62 fcid 0xea01ef dynamic
vsan 18 wwn 20:05:00:0e:11:13:97:b2 fcid 0xea0000 dynamic
interface vfc9
bind interface Ethernet1/9
no shutdown
interface vfc11
bind interface Ethernet1/11
no shutdown
interface vfc13
bind interface Ethernet1/13
no shutdown
interface vfc15
bind interface Ethernet1/15
no shutdown
interface vfc16
bind interface Ethernet1/16
no shutdown
vsan database
vsan 18 interface vfc9
vsan 18 interface vfc11
vsan 18 interface vfc13
vsan 18 interface vfc15
vsan 18 interface vfc16
vsan 18 interface fc2/1
vsan 18 interface fc2/2
vsan 18 interface fc2/5
interface fc2/1
no shutdown
interface fc2/2
no shutdown
interface fc2/3
no shutdown
interface fc2/4
interface fc2/5
no shutdown
interface fc2/6
interface fc2/7
interface fc2/8
interface Ethernet1/2
interface Ethernet1/3
interface Ethernet1/4
interface Ethernet1/5
interface Ethernet1/6
interface Ethernet1/7
interface Ethernet1/8
switchport mode trunk
interface Ethernet1/10
interface Ethernet1/12
interface Ethernet1/14
switchport trunk allowed vlan 1,180
spanning-tree port type edge trunk
interface Ethernet1/17
interface Ethernet1/18
interface Ethernet1/19
interface Ethernet1/20
interface mgmt0
ip address 192.168.5.93/24
line console
boot kickstart bootflash:/n5000-uk9-kickstart.4.1.3.N1.1.bin
boot system bootflash:/n5000-uk9.4.1.3.N1.1.bin
cfs ipv4 distribute
cfs eth distribute
interface fc2/1
interface fc2/2
interface fc2/3
interface fc2/4
interface fc2/5
interface fc2/6
interface fc2/7
interface fc2/8
vsan 18 is already up with 3 hosts, I'm trying to add a 4th. The port in question is eth 1/15, vfc 15. Status oper is down
#sho lldp nei
Remote Peers Information on interface Eth1/15
Remote peer's MSAP: length 12 Bytes:
00 c0 dd 11 33 26 00 c0 dd 11 33 26
LLDP TLV's
LLDP TLV type:Chassis ID LLDP TLV Length: 7
LLDP TLV type:Port ID LLDP TLV Length: 7
LLDP TLV type:Time to Live LLDP TLV Length: 2
LLDP TLV type:LLDP Organizationally Specific LLDP TLV Length: 61
LLDP TLV type:END of LLDPDU LLDP TLV Length: 0
#sho int vfc 15
vfc15 is down
Bound interface is Ethernet1/15
FCF priority is 128
Hardware is Virtual Fibre Channel
Port WWN is 20:0e:00:0d:ec:ef:38:ff
Admin port mode is F, trunk mode is on
snmp link state traps are enabled
Port vsan is 18
1 minute input rate 0 bits/sec, 0 bytes/sec, 0 frames/sec
1 minute output rate 0 bits/sec, 0 bytes/sec, 0 frames/sec
0 frames input, 0 bytes
0 discards, 0 errors
0 frames output, 0 bytes
Any ideas?
Thanks!
10-23-2010 09:06 AM
Configuration wise, I do not see anything standing out. A vFC will not come up until the host associated with it sends out a FLOGI frame. Make sure your CNA has the appropriate FCOE drivers and is initiating FLOGI. Also make sure the CNA supports the media type you are using.
10-23-2010 10:27 AM
Make sure your vlan is in the vlan database and the vsan is in the vsan database.
If you have a qlogic qle 8152, then you need a twinax cable.
