10-03-2012 03:37 AM
We are deploying a pair of Nexus 7009, running NX-OS version 6.0(4).
Customer is attaching HP servers running ESX via 2 x 10gig connections, 1 connection to each core switch.
Connection to the second switch goes down after a period of time with the error Ethernet4/13 is down (dcxNoACKin100PDUs, port: error)
Has anyone seen this before, FCOE is not enabled on the Switch.
Show interface output.
Dedicated Interface
Hardware: 1000/10000 Ethernet, address: 30f7.0de6.8aa4 (bia 30f7.0de6.8aa4)
Description: **** MPEP-ESX01 ****
MTU 1500 bytes, BW 10000000 Kbit, DLY 10 usec
Encapsulation ARPA
Port mode is trunk
auto-duplex, 10 Gb/s, media type is 10G
Beacon is turned off
Auto-Negotiation is turned on
Input flow-control is off, output flow-control is off
Rate mode is dedicated
Switchport monitor is off
EtherType is 0x8100
Last link flapped 00:17:34
30 seconds input rate 0 bits/sec, 0 packets/sec
30 seconds output rate 0 bits/sec, 0 packets/sec
Load-Interval #2: 5 minute (300 seconds)
input rate 0 bps, 0 pps; output rate 0 bps, 0 pps
RX
5 unicast packets 648 multicast packets 69 broadcast packets
722 input packets 100656 bytes
0 jumbo packets 0 storm suppression packets
0 runts 0 giants 0 CRC 0 no buffer
0 input error 0 short frame 0 overrun 0 underrun 0 ignored
0 watchdog 0 bad etype drop 0 bad proto drop 0 if down drop
0 input with dribble 0 input discard
0 Rx pause
TX
444 unicast packets 514724 multicast packets 11594 broadcast packets
526762 output packets 38946660 bytes
3 jumbo packets
0 output error 0 collision 0 deferred 0 late collision
0 lost carrier 0 no carrier 0 babble 0 output discard
0 Tx pause
5 interface resets
10-03-2012 07:10 AM
What type of 10Gig adapter do you have on the server? I suspect its a FCoE capable CNA and could be sending out DCBX TLVs at times. Do you have LLDP enabled on the Nexus? If LLDP is not needed, you can disable LLDP per interface with following command which should avoid the problem.
20-11-7010-N7k-Core-A(config)# interface ethernet 1/15
20-11-7010-N7k-Core-A(config-if)# no lldp ?
receive Enable LLDP reception on interface
transmit Enable LLDP transmission on interface
10-04-2012 07:54 AM
We have already applied those commands to one of the Nexus switches & it did resolve the issue.
My concern is that we shouldn't have to configure this as we are not using FCoE.
The servers have emulex adaptors & i am wondering why we were only seeing this issue on one of the Nexus Core switches?
Server team are adamant the problem is not the servers as the have the latest firmware/drivers.
Would like to prove it is not the Nexus!
10-04-2012 08:29 AM
If your servers are not doing FCoE, they should not be sending out DCBX TLVs in LLDP frame. I have had lot of experice with this issue on Nexus 5000 when servers are doing FCoE and this always turned out to be server not sending correct sequence numbers.
Here is a thread on it.
10-04-2012 08:31 AM
That is what i suspected, i need to investigate more with the server team!
03-07-2019 07:47 PM
Did you find the root cause?
Thank you very much.
