Patrick Born
This application note describes how to configure and deploy a SPA8800 in an Asterisk environment. It incluldes SPA8800, Asterisk sip.conf, and Asterisk extensions.conf files.
Also included is a troubleshooting section with sample traces showing registration and call flows.
Patrick Born
Hi SPA8800 owners and potential owners,
How can I help you with the SPA8800?
Do you need more information or examples? Let me know and I'll do my best to provide the content / help.
Patrick
finalconnect
Level 3
Level 3
How about a SPA8800 to UC540 configuration example- that is to add an additional 4 FXO ports to UC5x0 total capacity?
In the works. Check back in a couple of weeks.
Marcos
w.dehouwer
Community Member
Also maybe interesting might be to add a section to the document on how to integrate the spa8800 in asterisk using the web-gui (trixbox/asterisknow/...) And in due time the same document might be interesting for the integration into freeswitch.
DmytroSoloviov
Could you provide any idea how to integrate SPA8800 and CUCM?
hi pat, are you able to show me how to connect the spa8800 to an analog ptsn?> primarly so the outgoing failover works via the analog lines?
mreed
Did anything ever come of these extra documents people were requesting?  I have the Asterisk document but would love to see the UC500 or CUCM integration document.
Patrick Born
Hi Patrick,
There is no special configuration. The SPA8800's relays are normally closed so when power is applied, the relays open. When power fails or is removed, the relays close thus directly connection the Phone1 phone with the LINE1 PSTN line.
Patrick
Patrick Born
Hi mreed,
No. I checked about two weeks ago, late Sept 2010 and found that the documents were never written. If you have something, or know someone who has something documented, please feel free to share with the community.
Patrick
mreed
I'm working on getting it working with CUCM right now.  I'll post something if I get it.
ericgriffin1
I'm about to attempt getting one to work with CUCM.  Did anyone have any luck?
mreed
I did get the FXO ports to work with CUCM.  I only use it for outbound dialing on the FXO ports though. Here are some notes I started for configuring the device.
The real trick is setting up a new SIP Security Profile in CUCM.  Create a new profile and set the Outgoing Transport Type to UDP.  Then select that when creating the SIP trunk for the 8800.  You have to create one Trunk per FXO port.  You set the UDP port to match the one specified for each FXO port on the 8800, ie 5061, 5062,5063,5064
Connect to PC AUX port
Browse to http://192.168.0.1/admin/advanced
Click Wan Status
Set Static IP
Connect device to correct subnet using the Ethernet port
Click Voice Tab - Click System Set Password
Voice Line Tab
Set Proxy address to voice server
Use Outbound Proxy - No
davidrlloyd
I have SPA8800 routing 2 PSTN lines to our Asterisk Server. The PSTN lines are configured as Incomming Trunks in Asterisk and all functions work as expected. My problem is consistently poor voice quality on the outgoing voice only. i.e. When we take an inbound call from the PSTN,  we hear good quality voice, but the external caller complains of poor quality describing the sound as low volume and clipped. Can you advise any settings that I should look at to address this?
David
sven
We have SPA8800 configured according document: I have 2 questions:
1) (problem): Calls from anyone using a SIP Soft phone on a PC can route calls to the PSTN on the FXO ports: Is there a posibility to restrict only to Ip form Asterisk server? I tried registering, but this results dificult on my Asterisk, as I need then to have host=dynamic in the peer definition in the sip.conf and in my particular situation results imposible...
In the SPA8800 SIP settings on the line tab, I see a YES/NO value with name "Restrict Source IP" what is this and where do I put the IP to restict to?
2) (curiosity): in the DP for the FXO, we use (SO:nnnnnnnn@192.168.x.x:5060>) .... what stands the SO for, and what other options are there?
thanks,
Sven
cindy toy
Level 7
Level 7
Hi Sven,
Since you have question instead of a comment I suggest you post this question in the discussion area located here for help: https://supportforums.cisco.com/community/netpro/small-business/voiceandconferencing/ata
Cindy Toy
Cisco Small Business Community Manager
for Cisco Small Business Products
www.cisco.com/go/smallbizsupport
