07-21-2012 04:00 PM
We have a ESW 520 8-port currently on firmware version 2.1.1.19 (boot version 1.0.0.07, VID V01) - Serial number CBT15100AN2
The latest firmware version is 2.1.1.21, which we downloaded and via Maintenance, Software Upgrade, via HTTP performed an upgrade to this latest version - the upgrade appears to complete, logs show successful however when we restart the switch it still shows as 2.1.1.19 . Very strange!
Can someone please advise how to get the upgrade to successfully apply?
Kindest regards,
Dale.
Solved! Go to Solution.
07-21-2012 04:02 PM
Hi Dale,
Did you change the active firmware image to the new version before restarting? (Maintenance -> File Management -> Active Image)
Best,
David
Please rate helpful posts and identify correct answers.
07-21-2012 04:02 PM
Hi Dale,
Best,
David
07-21-2012 04:09 PM
David,
Thanks for such a question reply - I had tried that and after reboot still shows as 2.1.1.19
I decided to install the firmware upgarde again, change the active firmware to 2.1.1.21 again, restarted and this time it held.
Thank you for your assistance, all resolved.
Cheers,
Dale.
07-21-2012 04:12 PM
Dale,
Glad to hear its all resolved
Best,
David
