02-18-2019 08:04 PM
Hello all,
We are trying to setup Cisco's Call Home on 5548up switches.
We have managed to get the email component working and are able to get a full-txt email using the callhome test command.
We are configuring this to monitor interface up/down syslog events as the switches connect our services environment.
I have been trying to get CallHome to trigger an email notification by shut/no shut of a port with no success.
Should alerts trigger on an admin. shut/no shut of a port?
Have I missed anything in the configuration below?
Below is the output of a show run callhome all command on a configured 5548 switch:
5548_switch# sh run callhome all
!Command: show running-config callhome all
!Time: Tue Feb 19 13:56:11 2019
version 7.1(4)N1(1)
callhome
switch-priority 7
email-contact xxxxxxxx@xxxxxxxxx.xxx.xxx.au
phone-contact +613-XXXX-XXXX
streetaddress 200 Xx. Xxxxxxxxx St. Xxxxxxxxxx
destination-profile PDC_5548_1
destination-profile PDC_5548_1 format full-txt
destination-profile PDC_5548_1 transport-method email
no destination-profile PDC_5548_1 transport-method http
destination-profile PDC_5548_1 message-size 2500000
destination-profile PDC_5548_1 message-level 2
destination-profile full_txt
destination-profile full_txt format full-txt
destination-profile full_txt transport-method email
no destination-profile full_txt transport-method http
destination-profile full_txt message-size 2500000
destination-profile full_txt message-level 0
destination-profile short_txt
destination-profile short_txt format short-txt
destination-profile short_txt transport-method email
no destination-profile short_txt transport-method http
destination-profile short_txt message-size 4000
destination-profile short_txt message-level 0
destination-profile CiscoTAC-1 transport-method email
no destination-profile CiscoTAC-1 transport-method http
destination-profile CiscoTAC-1 message-size 5000000
destination-profile CiscoTAC-1 message-level 0
destination-profile PDC_5548_1 email-addr xxxxxxxx@xxxxxxxxx.xxx.xxx.au
destination-profile PDC_5548_1 alert-group all
destination-profile CiscoTAC-1 alert-group cisco-tac
destination-profile full_txt alert-group all
destination-profile short_txt alert-group all
transport email smtp-server xxxxxxxxxxxx.xxxxxxxxxx.xxx.xxx.au port 25 use-vrf default
transport email from xxxxxxxxxx@xxxxxxxxx.xxx.xxx.au
transport http use-vrf default
no transport http proxy enable
transport email smtp-server xxxxxxxxxx.xxxxxxxxx.xxx.xxx.au port 25 use-vrf default
enable
duplicate-message throttle
periodic-inventory notification
periodic-inventory notification interval 7
periodic-inventory notification timeofday 08:00
5548_switch#
Many thanks.
04-11-2019 08:43 AM
