11-23-2012 02:42 AM
Hi Brian,
We are trying to configure Callhome with a email services that had authentication.
We recive the following error when we does a test
trying to send test callhome message
warning:no callhome message sent
no email address configured for destination profile:full_txt
no email address configured for destination profile:short_txt
Error in transporting email message for CiscoTAC-1
SMTPclient: Host:1.1.1.1:unexpected reply: 530 Authentication required
The ip address of the smtp server is hiden for security.
Thanks in advance for your help.
Solved! Go to Solution.
11-26-2012 02:57 PM
It hit an error when transmitting
There is some code in IOS version 15.2T that allows username and password for the email server in Call Home per
CSCtn88293 callhome mail server support hostname:password:server address
The feature enhancement above is being used to integrate this feature into IOS routers, 6500, and 4500 code train. But this does not mean this feature enhancement migrates into NX-OS or other code trains.
Since I don't know what code or version your device is running or the configuration, as a first guess, I would say that the code your device is running does not support email authentication from that error message. The majority of call home devices today only support basic SMTP.
If your code supports this feature enhancement, you can enter the call home email server with the following 3 formats:
username:password@host
username@host
host
The last one is today's default supported format across all platforms for simple SMTP communication.
11-26-2012 02:57 PM
username@host
host
