problem with callhome nexus7000
birka.izik
hi
i configure nexus 7010 for callhome
when i try to send test it's work, when i try to send configuration it's work, when i try to send diag it's doesnt send anything
why is that ? and how can i fix it ?
the configuration:
version 5.1(3)
callhome
  switch-priority 7
  email-contact XXXXXXXXXXXX
  phone-contact XXXXXXXXXXXXXXXX
  streetaddress XXXXXXX
  destination-profile CiscoTAC-1 transport-method email
  no destination-profile CiscoTAC-1 transport-method http
  destination-profile CiscoTAC-1 message-size 5000000
  destination-profile CiscoTAC-1 message-level 0
  destination-profile full_txt transport-method email
  no destination-profile full_txt transport-method http
  destination-profile full_txt message-size 2500000
  destination-profile full_txt message-level 0
  destination-profile short_txt transport-method email
  no destination-profile short_txt transport-method http
  destination-profile short_txt message-size 4000
  destination-profile short_txt message-level 0
  destination-profile CiscoTAC-1 email-addr callhome@cisco.com
  destination-profile CiscoTAC-1 alert-group cisco-tac
  destination-profile full_txt alert-group all
  destination-profile short_txt alert-group all
  transport email from XXXXXXXXXXXXXXXX
  transport email smtp-server XXXXXXXXXXX port 25 use-vrf management
  transport http use-vrf default
  enable
  periodic-inventory notification
  periodic-inventory notification interval  30
  periodic-inventory notification timeofday 08:00
  duplicate-message throttle
the results :
DEVICE_A# callhome test inventory
trying to send test callhome inventory message
successfully sent test callhome inventory message
warning:
no email address configured for destination profile:full_txt
no email address configured for destination profile:short_txt
DEVICE_A# callhome send diagnostic
trying to send diagnostic callhome message
warning:no callhome message sent
thanks
izik
Lawrence Searcy
Please see
CSCub83379 callhome send diagnostic command does not activate CiscoTAC-1 profile
for information. Essentially, you have to create a new profile to send the diagnostic command. Here is the release note
Symptom:callhome send diagnostic command does not send a message when only CiscoTAC-1 profile
is configured
Conditions:Version 5.0(2a)
Workaround:Configure a copy of the CiscoTAC-1 profile using
  destination-profile myprofile
  destination-profile myprofile format XML
  destination-profile myprofile email-addr callhome@cisco.com
  destination-profile myprofile alert-group all
Further Problem Description:In order for the CiscoTAC-1 profile to be called to send a
message for the device, the alert group cisco-tac must be activated. The debugs show that this alert
group is called for the following commands:
callhome test
callhome send configuration
Unfortunately, it does not call the cisco-tac alert group for the command "Callhome send
diagnostic". This means in order for the device to send a message using that command, a second
profile must be configured that monitors the alert group diagnostic.
Lawrence Searcy
Please see
is configured
callhome test
