11-02-2021 05:15 AM
Hi all ,
I have moved SSM "smart software license on-prem" vm from DC to other one and need to change it IP address.
I tried to do so using the sameway for configuring new IP but it didn't work
please advise how to do so from console.
11-02-2021 05:19 AM
Are you using DNS Name, so you need to change the DNS A record pointing to new IP address.
what is not working explian more ? what is failing registration ?
11-02-2021 09:13 AM
nothing failed
I just moved the vm from site to different site and I need to change the ip to be routed according to the new site scheme
11-04-2021 01:11 AM
it solved
I will share the relevant document
11-04-2021 02:23 AM
Glad it is all good and appreciated your input and feedback we mark it as resolved and wait for your approach that will help others if they like to do the same process.
07-22-2024 11:57 PM
Can you share resolution? Changing IP address procedure for V8 is not documented any where that I can find.
