chnage current IP address of smart software license on-prem
Redash6174183
Hi all ,
I have moved SSM "smart software license on-prem" vm from DC to other one and need to change it IP address.
I tried to do so using the sameway for configuring new IP but it didn't work
please advise how to do so from console.
5 Replies 5
balaji.bandi
Are you using DNS Name, so you need to change the DNS A record pointing to new IP address.
what is not working explian more ? what is failing registration ?
BB
nothing failed
I just moved the vm from site to different site and I need to change the ip to be routed according to the new site scheme
it solved
I will share the relevant document
Glad it is all good and appreciated your input and feedback we mark it as resolved and wait for your approach that will help others if they like to do the same process.
BB
Can you share resolution?  Changing IP address procedure for V8 is not documented any where that I can find.
