Network essential
mojahidahmed
hello everyone
I have C9300 48 port and
After making a downgrade ( from 17.03.03 to 16.12.04) for the switch
I found in “show license usage “  command below.
The switch work as “Evaluation mode”
---before the downgrade
Switch#show license usage
License Authorization:
  Status: Not Applicable
network-essentials (C9300-48 Network Essentials):
  Description: C9300-48 Network Essentials
  Count: 1
  Version: 1.0
  Status: IN USE
  Export status: NOT RESTRICTED
  Feature Name: network-essentials
  Feature Description: C9300-48 Network Essentials
  Enforcement type: NOT ENFORCED
  License type: Perpetual
dna-essentials (C9300-48 DNA Essentials):
  Description: C9300-48 DNA Essentials
  Count: 1
  Version: 1.0
  Status: IN USE
  Feature Name: dna-essentials
  Feature Description: C9300-48 DNA Essentials
  License type: Subscription
---after downgrade
  Status: EVAL MODE
  Evaluation Period Remaining: 89 days, 23 hours, 57 minutes, 46 seconds
  Description:
  Count: 1
  Version: 1.0
  Status: EVAL MODE
  Description:
  Count: 1
  Version: 1.0
  Status: EVAL MODE
how can I return the license back from evaluation to Network-essential?
many thanks
balaji.bandi
  Count: 1
  Version: 1.0
  Status: IN USE
this is already network-essential (nothing going to happen to switch).
BB
 thanks for your reply.
please check the show license usage
-after downgrade
thnks
That is the basic License come with every switch, so you need to worry much :
  Description:
  Count: 1
  Version: 1.0
  Status: EVAL MODE
generally you have  90-days to register with a smart License below guide provide you with steps : (if not nothing happens to device, it work as expected, but compliance you can do the process)
https://community.cisco.com/t5/cisco-software-documents/new-deployment-method-for-smart-licensing/ta-p/4167670
BB
I am not worried.
The "essentials" is the lowest license feature set.  If-and-when the time comes, there is no license level to "downgrade" the license to but "essentials" level.
