Add Nexus to CSPC 2.7.4
muath1987
Hello Dears
I tried to add Nexus switch 3548 to CSPC when was the running version is 2.5.0, in that time the nexus switch went down i dont know if that was a bug or something else but the whole switch went down, right now the running version is 2.7.4 can i know if i will face the same scenario or is there any bug affecting nexus 3548. Many thanks
Thanks for the info. Do you still have any data about the crash? I would recommend opening a TAC case about the crash. We have not seen CSPC cause any issues with the Nexus running that version.
5 Replies 5
Chris Camplejohn
What NX-OS version was on the 3548 when you tried with CSPC 2.5 and what version is on it now?
hello Cris
here is the version that was running and still on the device
#  show ver
Cisco Nexus Operating System (NX-OS) Software
TAC support: http://www.cisco.com/tac
Documents: http://www.cisco.com/en/US/products/ps9372/tsd_products_support_serie
s_home.html
Copyright (c) 2002-2016, Cisco Systems, Inc. All rights reserved.
The copyrights to certain works contained herein are owned by
other third parties and are used and distributed under license.
Some parts of this software are covered under the GNU Public
License. A copy of the license is available at
http://www.gnu.org/licenses/gpl.html.
Software
  BIOS:      version 2.0.6
  loader:    version N/A
  kickstart: version 6.0(2)A8(3)
  system:    version 6.0(2)A8(3)
  Power Sequencer Firmware:
             Module 1: version v2.1
  BIOS compile time:       12/26/2014
  kickstart image file is: bootflash:///n3500-uk9-kickstart.6.0.2.A8.3.bin
  kickstart compile time:  10/28/2016 20:00:00 [10/29/2016 04:50:59]
  system image file is:    bootflash:///n3500-uk9.6.0.2.A8.3.bin
  system compile time:     10/28/2016 20:00:00 [10/29/2016 05:17:12]
Hardware
  cisco Nexus 3548 Chassis ("48x10GE Supervisor")
  Intel(R) Pentium(R) CPU  @ 2.00GHz with 3794024 kB of memory.
  Processor Board ID FOC20036DAN
  Device name: LB-HQ-Agg-SW7
  bootflash:    4014080 kB
Kernel uptime is 293 day(s), 18 hour(s), 11 minute(s), 3 second(s)
Last reset at 448923 usecs after  Tue Jul 18 12:27:34 2017
  Reason: Reset Requested by CLI command reload
  System version: 6.0(2)A8(3)
  Service:
plugin
  Core Plugin, Ethernet Plugin
unfortunately i don't have the crash file, I will try to add it and see
what will happen :)
Could you please provide me with any bug related to Nexus ?
