All data gone from the Portal
ksforeman
I have logged into the SNTC portal and all our previously uploaded data is now gone. My colleague has also attempted to login and gets the same.
How can we find out what has happened to our data ?
Kevin
10 Replies 10
Jarrett Pomeroy
Hello Kevin,
SNTC recently had a new portal release (4.0) which required that all manual uploads be re-submitted again. I can see that you were using the CSPC manual File Import method, would you be able to issue a new upload and check to see if the data starts to populate again?
Thank you,
Jarrett
Ok, will do. Didn't want to start one off until I knew why it had disappeared.
Kevin
I've re-uploaded the last import and data is there now. But the IP addresses aren't showing correctly any longer. For example, they are in the format 0.0.2.128 - This looks to be for all devices.
Kevin
Hello ksforeman,
Can you please check and see if the IPs are also reflected in your CSV File which was used for importing?  The SNTC portal will reference those IPs when processing CSV files.
Thank you,
Jarrett
It's not a CSV, it's the downloaded transport file from the collector and the same file I used in my last upload prior to these issues.
Hello ksforeman,
This may indicate that the masking feature of the CSPC was enabled.  To check the settings for the masking rules, on the CSPC GUI Select "Device Management" -> Collection Rules -> Manage Data Collection Profiles -> Select Modify SNTC Profile.  After the settings have been changed, you will need to rerun the Collection Profile and grab a new file for the manual upload.
Thank you,
Jarrett
I will check, but this is the same download we've used previously and we've never masked the IP addresses at all. It is exactly the same file we used for the previous upload prior to the portal upgrade.
Kevin
The masking settings are not selected. Any idea's why it's no longer working ?
Kevin
Hello ksforeman,
Can you please check and see if the Masking Settings have been enabled for any Collection Profiles on your CSPC?  The options to mask will be enabled for all service named upload files.
Thank you,
Jarrett
I've just looked through the file and it has a 'dav' file - this contains the device names and IP addresses as I'd expect to see them.
