API documentation for CSPC
rloyola22
I would like to perform API calls from a MuleSoft application to our Cisco PSS Collector. However, I have only found limited documentation regarding the built-in XML API Console from the GUI.
Could you please provide the necessary requirements to enable API access on the Cisco collector? Additionally, I would appreciate it if you could share any available documentation that could assist us in making API calls from remote appliances.
rloyola22
Does anybody from Cisco can confirm if Cisco collector is compatible with https://apiconsole.cisco.com/ ?
manuwidmer
Hi @rloyola22  please have a look at  https://github.com/lumean/cisco-cspc   I built a small python client to interact with the CSPC collector.
Basically you can use the same XML API as in the built in GUI console - you can look at the source code to see how to call the API from remote.
You need to HTTP POST  to  "https://<CSPC IP>:8001/cspc/xml"    it you can supply your credentials using basic Auth, see
https://github.com/lumean/cisco-cspc/blob/main/src/cspc_api/cspc_api.py#L44
and
https://github.com/lumean/cisco-cspc/blob/main/src/cspc_api/cspc_api.py#L67
rloyola22
@manuwidmer, My company want to get contract, alerts, EoS, etc informtion via API. Is this feasible using your script?
Also, Can you confirm is Cisco collector can be managed via  https://apiconsole.cisco.com/ API ??
manuwidmer
Hi @rloyola22 , no that is not possible with my script.   My script is for interacting with the CSPC VM that runs locally in your enterprise network, so you could automate inventory management (adding/removing devices to the seed file, trigger discovery, etc.).  The CSPC VM doesn't have EoX information, it is just responsible for inventory/telemetry collection.
If you need PSIRT, EOX  etc information please checkout the support-APIs or the  PSIRT openVuln API:
- https://developer.cisco.com/docs/support-apis/user-onboarding-process
- https://developer.cisco.com/docs/psirt/introduction/
If you need automated notifications please check these:
- https://www.cisco.com/c/en/us/support/web/tools/cns/notifications.html
- https://cway.cisco.com/mynotifications
