Call manager is not discovered in CSPC
spazziani
Cisco collector fails to discover CUCM. The Collector returns the message "DEVICE UNREACHABLE or INCORRECT SNMP CREDENTIALS" The connectivity test was successfully carried out and the CLI command "snmpwalk -v 2c -c <snmp-Community> Device IP address" was tested and the CUCM responds without a problem.
jofrumki
To be sure the CSPC is configured correctly, please rerun the snmpwalk to the CUCM and copy the SNMP RO string from the CSPC configuration while doing so, it's possible there is a typo.
Thanks for answering.
All settings are correct. SNMP was entered correctly in CSPC.
