Cannot find kvm image of CSPC
MPFMPF49115
Hi all:
We are trying to download a qcow2 or OVA file for CSPC but we only see the .zip installation pack on the download center, can anyone tell me if we have that option for run the cspc in KVM applaiance?
Sanapshot attached.
Thanks in advance
adias
Not every minor version are in ISO or OVA format. most of the minor versions are only upgrade patches releases.
The last posted ova and ISO was in 2.8.1.4 and you can find it on that folder.  The official virtual process supported is Vmware. but with the ISO you should be able to deploy Hyper-v or KVM.
here is the link of the ISO and OVA
https://software.cisco.com/download/home/286312935/type/286312958/release/2.8.1.4
adias
got it!!! thanks!
