Cannot Login as admin
Hello, I can no longer login as admin via CLI.  I am running 2.7.4 and can login via the GUI & collectorlogin/root.
I have reset the admin password via root, restarted the admin service, and rebooted the server - still does not work.
The error I get when logging in as admin is:
java.net.ConnectException: Connection refused (Connection refused)
at java.net.PlainSocketImpl.socketConnect(Native Method)
at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:350)
at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:206)
at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:188)
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392)
at java.net.Socket.connect(Socket.java:589)
at java.net.Socket.connect(Socket.java:538)
at java.net.Socket.<init>(Socket.java:434)
at java.net.Socket.<init>(Socket.java:244)
at com.cisco.ca.ss.lcm.adminshell.client.ShellClient.main(ShellClient.java:51)
Error occured: could not connect to the database server.
Please make sure mysql database server is up and running.
adias
Hello please do the following steps from root and let me know the results:
PRIOR TO DO THE FOLLOWING COMMANDS STEPS IF NOT DONE YET PLEASE DO THE FOLLOWING
From root, you can run this command to copy the following log into a directory which will allow you to export the files from the CSPC GUI:
# cp /opt/cisco/ss/adminshell/logs/nohup.out /opt/cisco/ss/adminshell/applications/CSPC/logs/KRISVOUTZ_M8756_nohup.out
# cd /opt/cisco/ss/adminshell/applications/CSPC/logs/
# chown casuser:casusers /opt/cisco/ss/adminshell/applications/CSPC/logs/KRISVOUTZ_M8756_nohup.outlogs.JPG
SEND ME THE LOG IN PRIVATE AND ONCE WE REVIEW I WILL LET KNOW IF WE WILL PROCESS THE  BELOW OR IF ADDITIONAL STEPS MAY BE NECESSARY
Once you are in the the CLI as root run the below commands: note each one of the following 4 commands below are in one single line
#  /bin/sh /opt/LCM/bin/sqliteToDerbyScripts_shell.sh "connect 'jdbc:derby://localhost:1527/opt/LCM/info/schedulerdb;create=true;user=app;password=password';" "delete from sss_qrtz_cron_triggers;"
# /bin/sh /opt/LCM/bin/sqliteToDerbyScripts_shell.sh "connect 'jdbc:derby://localhost:1527/opt/LCM/info/schedulerdb;create=true;user=app;password=password';" "delete from sss_qrtz_triggers;"
# /bin/sh /opt/LCM/bin/sqliteToDerbyScripts_shell.sh "connect 'jdbc:derby://localhost:1527/opt/LCM/info/schedulerdb;create=true;user=app;password=password';" "delete from sss_qrtz_job_details;"
# /bin/sh /opt/LCM/bin/sqliteToDerbyScripts_shell.sh "connect 'jdbc:derby://localhost:1527/opt/LCM/info/schedJobDetails;create=true;user=app;password=password';" "delete from schedJobDetails;"
Finally, restart the adminshell service with the command
# service adminshell restart
and you hopefully you may now have access to the adminshell once more.
