Cisco CSP Collector 2.10 to 2.11
gustavosamuel
Hi, my question is to know the justification for going from having 40GB with the VM in 2.10; to needing 1000 GB with the vs. 2.11
I await some comment.
Thank you very much
5 Replies 5
adias
It is not clear where you getting these numbers CSPC  for the service SNTC  2.10 required minimal 250G  2.11 require the same
adjunto captura
please provide the link you got that screen shot from
juanfsan
enrirami
The requisites to install a CSPC 2.11 are the same as they were for 2.10. Please check these documents.
https://www.cisco.com/c/dam/en/us/support/docs/services/sntc/ISO-App-Note.pdf
https://www.cisco.com/c/dam/en/us/support/docs/cloud-systems-management/common-services-platform-collector-cspc/CSPC-Quick-Start-Guide.pdf
It depends of the amount of devices you are going to manage with the CSPC.
Kind Regards,
Enrique Ramirez
