06-05-2017 10:02 AM
I have a problem with running report in CSP Collector 2.7
The report for managed devices doesn't show serial numbers in it.
The SerialNumber field is empty while it did have information in version 2.2
Solved! Go to Solution.
06-07-2017 07:48 AM - last edited on 10-13-2017 04:16 PM by Cheri Fairbrother
Hello Sergey,
For CSPC 2.7, you can enable the serial number check by updating the below settings. Can you please see if after this is enabled and rerunning a discovery if you're able to view the serial numbers in the report?
Settings -> Discovery Settings -> Serial Number Duplicate Check -> Yes
Thank you,
Jarrett
06-06-2017 02:30 PM
Hello Sergey,
Thank you for your question. One of our experts will respond shortly to assist.
Cheers,
Cheri
06-09-2017 04:09 PM
Hello Sergey,
I have the same problem. Have you found your answer?
Yang
06-09-2017 06:42 PM
Just be aware that this will also prevent the discovery of devices with duplicate serial numbers. For example, if you put all the VDCs of a Nexus 7K into the CSPC, I believe you will only get one of them. So there are negative consequences, which is why it is disabled by default. I would consider leaving it disabled and using the SNTC portal to see serial numbers instead.
06-09-2017 04:13 PM
Actually enabling "Serial Number Duplicate Check" solved the problem.
06-06-2017 05:51 PM
The serial number column will be populated if the CSPC is able to successfully find a serial number of the device in ENTITY-MIB during the initial discover job. Can you please see if the serial numbers are available on the SNTC Portal after performing an inventory and upload?
Thank You,
Jarrett
06-07-2017 05:38 AM
Hi Jarrett,
The serial numbers are in SNTC portal but not in the collector.
Sergey
Hello Sergey,
Thank you,
Jarrett
06-12-2017 05:53 AM
Hi Jarrett,
The serial number check did solve the problem.
Thank you for you help
Much appreciated
Sergey
