CSCP Software Update
millerlw
Good afternoon,
We are running CSPC 2.11 and when trying to run the software update from within the CSPC via the Software Update tab, it is failing.  I had our Security department whitelist the URLs per the CSPC Software Upgrade guide, but it still appears to be failing with the message "Please check the log file for more details".  It tells me nothing else.
My CCO UserID is millerlw and we have been running the CSPC for several months, so this is not a new install but I believe it is the first time we have tried to update the software.
I have the log files downloaded and can upload them if necessary.
Thank you,
Leonard
jboyanob
Hello, @millerlw
I hope you are having a great day.
Thanks for the info provided. In this case, please try to follow the steps provided in the guide attached.
This guide is updated for 2.11.0.1 patch.
You should be able to install the patch using CLI. You should have your collectorlogin and root passwords to proceed.
Kindest regards,
11 Replies 11
jboyanob
Hello, @millerlw
Thank you for contacting Cisco and Global CX - Smart Services Support Team.
Please provide the next information on a private message, so I can assist you further:
- Company name.
- Email.
- CR Party Id.
- Please attach the logs from CSPC.
Kindest regards,
Log files attached.
Leonard
jboyanob
Hello, @millerlw
Kindest regards,
millerlw
Thank you, I have downloaded the file but just need to figure out how to get it to the server since it doesn't support FTP or TFTP.
Just so you know, I have to do it this way because the adminshell does not work, unless I'm doing it wrong.  I am getting the following:
*****PID file exists. But Adminshell service is not completely up.*****
*****If adminshell is restarted manually, please wait for 15-20 mins .*****
*****If adminshell is not restarted manually Please check nohup.out log at /opt/cisco/ss/adminshell/logs for any errors .*****
*****Try restarting adminshell once using 'service adminshell restart' command .*****
UPDATE:
I was finally able to get the adminshell working, but it's a little late in the date to start an upgrade, so I will try it again tomorrow.
Leonard
jboyanob
Hello, @millerlw
I hope you are doing great.
Thanks for the update. Please keep me posted on how the process goes.
Kindest regards,
millerlw
Good morning,
I had to do it all from the adminshell, but I think it worked and if that's the case, thank you very much for your help, it is greatly appreciated.
CSPC Show vesionCSPC Show vesion
Leonard
jboyanob
Hello, Leonard.
Thanks for the update. You are welcome!
Glad to know that the update is now completed and all looks fine.
Kindest regards,
Beazle
Can anyone help me with the command to download the collector_2.11.0.3_Build-4.zip to the cspc server?
adias
What problem are you having doing so?
millerlw
You should be able to do it from the Software Update tab in the GUI.  Or from the CLI you can do the following:
check appliance update
check updated -d
download (version#)
apply last or apply *
Leonard
It kept failing to connect from the gui, but using those commands on the cli seemed to do the trick. I am not much of a linux guy so many thanks!
