CSPC 2.10 GUI password reset
CiscoPR785291
Hello, I am having a problem accessing the Cisco Collector portal because my password has expired.
Is there any way to recover it?
I have console access with root, administrator and the Collector user.
I thank you in advance for your prompt help.
jelopezm
Hello @CiscoPR785291
Thank you for contacting Cisco.
I understand you are having inconveniences to logging into the CSPC GUI due to the credential has expired.
Firstly, I suggest trying to reset the password using the security questions by opening the GUI, entering the admin user and clicking on the "Forgot Password?" button (as shown in the screenshot), if you face an error message please share it here or if for some reason you don't remember or are unable to reset the credentials through this method, I kindly recommend deploying the most recent version of the CSPC, which is 2.11. This is to ensure uninterrupted service and access to the latest security enhancements.
Below you will find the quick start guide for deploying the CSPC.
https://www.cisco.com/c/dam/en/us/support/docs/cloud-systems-management/common-services-platform-collector-cspc/CSPC-Quick-Start-Guide.pdf
Find below the 2.11 OVA file.
https://software.cisco.com/download/home/286312935/type/286312958/release/2.11
Best Regards,
Jesus
jelopezm
Best Regards,
Jesus
Hello good morning,
Thanks for the help, I created another virtual machine again and redid the configuration, since I forgot what to put in the security questions.
But thank you very much for the help.
Greetings
