01-13-2022 06:10 AM
When registering (the trial option) it fails after approximately 10 min with error message:
"Applying trial license on CSPC timed out. Please try Again"
I tried it several times with same result. Attached are some screenshots showing the problem and also some logs.
admin# show version -d
Build-name : Collection Platform Software 2.10
Package-type : ServicePack
Version : sp-30.3.0-0-0-lnx64
Component : CSPC Base
Version : 2.10
Package-type : JeOS
Version : jeos-30.3.0-0-lnx64
Component : AdminShell
Version : 1.9.4
Component : LCM
Version : 1.9.4
Component : CASP
Version : 2.10
Component : ConcsoTgw
Version : 1.8.0
Component : Hardened CentOS
Version : 7.9 patch#2009
Solved! Go to Solution.
01-17-2022 05:10 AM
Hi danielbarri,
The Trial version isn't supported temporarily. The Development team is working on it and will possibly find a resolution soon.
Thanks & Regards
Aishwarya Bhatnagar
01-13-2022 06:21 AM - edited 01-13-2022 09:02 AM
Hi danielbarri,
Hope you are you doing well!
Thank you for sharing the details. We are looking into the issue you posted and will reach out to you soon with an update.
Thanks & Regards
Aishwarya Bhatnagar
01-13-2022 09:02 AM - edited 01-13-2022 09:03 AM
Hi danielbarri,
We would like to inform you that for all the collectors (Trial certificate, upgrade, cco setup) the Trial version isn't supported due to which you are receiving the "Timed Out" error. The CSPC collector requires the services of either SNTC or BCS.
If you are looking to avail the SNTC services, then in this case you need to create an SNTC account and generate the Entitlement for the same.
Thanks & Regards
Aishwarya Bhatnagar
01-17-2022 12:08 AM
Is the Trial Certificate not supported temporarily or it won't be supported at all? If it won't why is this option available in the quick start wizard?
01-17-2022 05:10 AM
Hi danielbarri,
Thanks & Regards
Aishwarya Bhatnagar
01-31-2022 04:07 AM
Hi aibhatna,
I also tried the trial version (today 31/1/22) and i get also the time-out.
Do you have an estimation date on when this issue will be fixed?
01-31-2022 11:52 AM
Hi panoschatz,
We would like to inform that right now there is no ETA decided. However, if there is any update on this we will surely notify you.
Thanks & Regards
Aishwarya Bhatnagar
02-21-2022 07:30 AM
I think still isn't supported temporarily. Am I right?
02-21-2022 01:44 PM
Hi jczifra,
Yes, you are correct.
Thanks & Regards
Aishwarya Bhatnagar
07-13-2023 07:36 AM
Hello after more than 1 one year. Does CSPC 2.10.0.1 support the option TRIAL License ?
YES or NO, if NO, why that option is in the wizard ?
