Showing results forĀ
Search instead forĀ
Did you mean:Ā
CSPC 2.7 Reports - Macro
lliureferre
I am generating Inventory and Alarms reports from a CSPC 2.7 with Smart Net Total Care portal v3.10, and I am having problems at using the "Template Smart Services Portal  Dashboard 3-6_v2.xlsm" macro to generate graphs with the data of the reports. The macro seems to work but the data in the dynamic tables generated is either wrong or empty.
Does anyone have had the same problem? Do you know if there is a newer version of this macro?
Thanks in advance.
DeannaDavenport
I had this same issue.  If you remove the MAC address column and load your reports it will work.
7 Replies 7
DeannaDavenport
It worked!!
Thanks a lot.
hutay
Hi, where to download this macro?
Hello Hutay,
You can reference these links:
Thank you,
Jarrett
Hi Jarrett,
Is there any way to get the latest version of the macro template, please.
Many thanks in advance.
Hi There,
The latest macro report can be found here -> https://www.cisco.com/c/en/us/support/services/sntc-portal/index.html
Thanks!
Jarrett
Many thanks, Jarrett!
