CSPC can not select "Chanche alert status" in the "Actions" box on the Alerts tab
serviciosbvs
In the alerts tab, I can not change any of the conditions of the alerts status (when i select Actions tab - "Select a Row" or "Select 2 or more rows to", I can not select anything inside them). i need help with this problem, thanks
Hi Juan,
You can respond to the alert through Administration - Active Alerts.
The screenshot that you are referring to is of Alerts - Field Notice. From here you can change the status of "Ignored" alerts back to Active.
You may want to go through Alert Administration video to know more.
Suchita
5 Replies 5
Jarrett Pomeroy
The "Change Alert Status" will become selectable after selecting an alert/row using the checkboxes displayed on the left of each alert. After you have 1 or more boxes checked, you will be able to select the options to change alert status.
Thank you,
Jarrett
Thanks for your help Jarrett
but now I get a blank window and then it shows me an error, which is where I'm not allowed to change the status of the alert. Do you know what this is?
I leave attached the images
Thank you.
Juan Diego Abreu
Hi Juan,
Suchita
Thanks Suchita.
I was able to solve the problem!
Juan.
Suchita Shewale
Can you please private message me with your account details?
Please share customer name, inventory and the report that you are referring to. Also include the CCO ID.
Suchita
