CSPC Colletor - Azure
Hi guys, what's up?
I would like to know if it is currently possible to install the Collector in the cloud, more specifically in Azure.
losorioj
Hello stefano.alcantara@2s.com.br
Thank you for contacting Cisco and Global CX - Smart Services Support Team.
Replaying to your question please note that:
This installation is technically possible, to install a Collector in the Azure cloud, however, Cisco does not support Azure deployments for the OVA, only VMWare on ESXi.
Kind regards,
losorioj
Kind regards,
Ruben Cocheno
Yes, it's possible but as suggested by @losorioj  is not supported by Cisco.
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
Rubens, what's up?
The biggest problem is that the Cisco Collector is not approved in the Azure Market Place.
For the installation, my technical team used it in our test environment, using the “AZURE MIGRATION TOOL” process.
