CSPC Devices All no Show, serial numbers upload
jeff.oak
Hello Team,
I need a support, for customer with CSPC problem configured ok, but the upload is only taking part of the devices.
Returning on the portal and reports without serial number.
Already checked, the devices SNMP, SSH credentials ok.
Version 2.8.1.3 CSPC !
Jeff
I'm also not able to see serial numbers in the SNTC either under 'All Equipment' or 'Custom Inventory'. I do see serial numbers in the CSPC. This is a recent issue and used to work correctly for me. I'm running version 2.8.1.5
jumin
Hey jeff.carvalho,
I believe you are seeing this due to bug ID CSCvq89357.  Contract and alert data should not be affected by this.  For 'All Equipment' and 'Custom Inventory' tabs, you should  still see serial numbers in the 'Collected SN' field.
Justin
Hi team,
Thanks, I did exactly that upgrade from version "2.8.1.5" on two Customers, and solved.
best regards !
