Trouble uploading CSV to service.cisco.com File name : asacsv.csv Import Errors: Operation could not be complete. [Unable to perform the operation = File Import failed. Error in CSV headers.]
cslusser
Hello all,
I need to import my ASA information to have access to software downloads. When I attempt to upload the file, this is the message I receive:
Below is the formatting of the file:
Hostname,IPAddress,SerialNumber,ProductID
xxx,10.0.xxx.xxx,xxxxxxxxxxx,ASA-5506
Please advise.
jumin
Hey cslusser,
Are you using the template that is provided in the SNTC Portal?  If you have admin access, you can go to the 'File Import' tab on the left dashboard.  After selecting 'CSV File Import' option, you should be able to download the sample CSV file.
Justin
Jumin,
Yes, I have viewed the sample CSV and used it as a template.
Hey cslusser,
I will request more info via PM.
Justin
