CSPC Password Expiry
MetCW_2020
Hi folks
To reset the admin cli or collector password it seems to be in the range 1 - 90 days.
Is it possible to set to infinite? 90 is too short.
Hello @MetCW_2020
In keeping with Cisco InfoSec requirements, the password expirations are hardcoded into the Linux configuration files and unfortunately we cannot provide support to modify these settings. If you were so inclined to search how to remove the expiration of Linux users we certainly could not stop you, but we may not be able to assist with future access issues should they arise.
balaji.bandi
if you have 2.8 somewhere have option no password expiry cant remember.
you can not change 90days that is the default.
BB
2.8 are your referring to the GUI? yes there is the option for GUI but what about the CLI.
i am referring to the cli admin /root / collector where default its 90days max. Can it be infinite.
Hello @MetCW_2020
