CSPC Stuck in Apply-in-progress
RicTodd89
I am trying to patch our CSPC to version 8.1.1.2.  It downloaded successfully, but it is still currently stuck in apply-in-progress.
Here is the output after running #show apply:
admin# show apply
Version Number : sp-30.0.4-0-0-lnx64
Status : Applied
Start Time : May/01/2018 18:02:19
End Time : -
Version Number : sp-30.1.0-1-0-lnx64
Status : Apply-in-progress
Start Time : Dec/13/2018 19:33:56
End Time : -
Version Number : sp-30.1.1-2-0-lnx64
Start Time : Mar/19/2019 22:49:23
End Time : -
I see that the last update I attempted was also stuck in apply-in-progress.  I have root access to the device.
Can someone please assist?
9 Replies 9
Ye Liang
Under "admin" user, please provide output of show version -d.
Under "root" user, please go to /opt/LCM/logs and show output of "tail -50 install" and "tail -50 apply".
Ye
admin# show version -d
Build-name : Collection Platform Software 2.8
Package-type : ServicePack
Version : sp-30.1.0-0-0-lnx64
Component : CSPC Base
Version : 2.8
Package-type : JeOS
Version : jeos-30.1.0-1-lnx64
Component : AdminShell
Version : 1.8.1
Component : LCM
Version : 1.8.1
Component : CASP
Version : 2.8.0.1
Component : ConcsoTgw
Version : 1.7.3
Component : Hardened CentOS
Version : 6.10 patch#0
keytool error: java.lang.Exception: Certificate not imported, alias <concsoweb3-prd> already exists
Service Name : COLLECTOR
empty
Local DB and SchedulerDB are not in sycn so jobs scheduled will be lost
Changing log_group value in auditd
Stopping auditd: [ OK ]
Starting auditd: [ OK ]
Archive: LCM_DERBY_Scripts.zip
inflating: /opt/LCM/bin/apply.sh
inflating: /opt/LCM/bin/asd-download.sh
inflating: /opt/LCM/bin/autoupdate-init.exp
inflating: /opt/LCM/bin/cmd-exec.tcl
inflating: /opt/LCM/bin/decryptor.sh
inflating: /opt/LCM/bin/downloadResultUpdate.sh
inflating: /opt/LCM/bin/getDependencyList.sh
inflating: /opt/LCM/bin/ida-download.sh
inflating: /opt/LCM/bin/lcmagent-apply-check.tcl
inflating: /opt/LCM/bin/lcmagent-apply-count.tcl
inflating: /opt/LCM/bin/lcmagent-apply.tcl
inflating: /opt/LCM/bin/lcmagent-apply-wrapper.tcl
inflating: /opt/LCM/bin/lcmagent-download.tcl
inflating: /opt/LCM/bin/lcmagent-system.tcl
inflating: /opt/LCM/bin/LCMDecryptor.jar
inflating: /opt/LCM/bin/packaging.sh
inflating: /opt/LCM/bin/restart.sh
inflating: /opt/LCM/bin/Resume.sh
inflating: /opt/LCM/bin/status_update.sh
inflating: /opt/LCM/bin/updateApplyCheckData.sh
inflating: /opt/LCM/bin/updator.sh
lcmuptime.sh cronjob doesnot exit , so creating lcmuptime.sh cronjob
remotelogin exists!
removing remotelogin from ssh config
Rebooting the appliance now
Finished execution of post-install scripts in package jeos-30.1.1-2-lnx64 ...
Upgrading Derby DB
Installing Derby DB 10.14.2.0
Derby DB Upgraded
Inside Preinstall
[Tue Mar 19 18:53:13 EDT 2019] Executed pre-install scripts
[Tue Mar 19 18:53:13 EDT 2019] Executing install script for "Hardened CentOS"
[Tue Mar 19 23:11:52 UTC 2019] Executed install script for "Hardened CentOS"
[Tue Mar 19 23:11:52 UTC 2019] Install script for "Hardened CentOS" returned success
[Tue Mar 19 23:11:52 UTC 2019] Executing install script for "LCM"
[Tue Mar 19 23:12:08 UTC 2019] Executed install script for "LCM"
[Tue Mar 19 23:12:08 UTC 2019] Install script for "LCM" returned success
[Tue Mar 19 23:12:09 UTC 2019] Executing install script for "AdminShell"
[Tue Mar 19 23:18:33 UTC 2019] Executed install script for "AdminShell"
[Tue Mar 19 23:18:33 UTC 2019] Install script for "AdminShell" returned success
[Tue Mar 19 23:18:34 UTC 2019] Executing install script for "ConcsoTgw"
[Tue Mar 19 23:19:20 UTC 2019] Executed install script for "ConcsoTgw"
[Tue Mar 19 23:19:21 UTC 2019] Install script for "ConcsoTgw" returned success
[Tue Mar 19 23:19:21 UTC 2019] Executing install script for "CASP"
[Tue Mar 19 23:19:22 UTC 2019] Executed install script for "CASP"
[Tue Mar 19 23:19:22 UTC 2019] Install script for "CASP" returned success
[Tue Mar 19 23:19:22 UTC 2019] Calling Procedure
[Tue Mar 19 23:19:23 UTC 2019] Calling updator.sh
Inside update script
Order Id :
Package Name :
Count :
update next package to install
[Tue Mar 19 23:19:24 UTC 2019] End of Script Execution
[Tue Mar 19 23:19:24 UTC 2019] End of Procedure
[Tue Mar 19 23:19:24 UTC 2019] Executing post-install scripts
Current SP :
Current JeOS :
Hostname : CSPC01.corp.local
Timezone : UTC
Replaced scripts with Derby statements
[Tue Mar 19 23:20:07 UTC 2019] Executed post-install scripts
[Tue Mar 19 23:20:07 UTC 2019] Installation of software package of type "JeOS" completed successfully
[Tue Mar 19 23:20:08 UTC 2019] --Component--CASP----jeos-30.1.0-1-lnx64--
[Tue Mar 19 23:20:08 UTC 2019] --Component--ConcsoTgw----jeos-30.1.0-1-lnx64--
[Tue Mar 19 23:20:09 UTC 2019] --Component--AdminShell----jeos-30.1.0-1-lnx64--
[Tue Mar 19 23:20:10 UTC 2019] --Component--LCM----jeos-30.1.0-1-lnx64--
[Tue Mar 19 23:20:10 UTC 2019] --Component--Hardened CentOS----jeos-30.1.0-1-lnx64--
[Tue Mar 19 23:20:11 UTC 2019] --JeOS--JeOS----jeos-30.1.0-1-lnx64--
[Tue Mar 19 23:20:11 UTC 2019] status db updation completed
apply.sh - 0------exit status
[Wed Mar 20 16:20:38 UTC 2019] Apply TCL Called with arguments "SP" and "/opt/LCM/tmp/sp-30.1.1-2-0-lnx64"
[Wed Mar 20 16:20:38 UTC 2019] Inside existence of status db
[Wed Mar 20 16:20:40 UTC 2019] Package file "/opt/LCM/tmp/sp-30.1.1-2-0-lnx64" not found
You have new mail in /var/spool/mail/root
From the CLI please run the command and make note of the file location to use in the next command;
find / -name sp-30.1.1-2-0-lnx64.zip
Then run the command;
screen /opt/LCM/bin/lcmagent-apply.tcl SP /path/to/file/sp-30.1.1-2-0-lnx64.zip
You can then press CRTL+A+D and monitor the installation using the command;
tailf /opt/LCM/logs/install
This may take some time to start initially so please give it plenty of room to run.
I ran the command you mentioned and waited about a day.
Here are the results when going back to the collectorlogin:
[collectorlogin@CSPC01 ~]$ tailf /opt/LCM/logs/install
remotelogin exists!
Then from the regular admin account login:
admin# show version
admin# show apply
Status : Applied
End Time : -
End Time : -
End Time : -
Please find the Troubleshooting guide here, https://www.cisco.com/c/dam/en/us/support/docs/cloud-systems-management/common-services-platform-collector-cspc/CSPC_Troubleshooting_Guide.pdf
and reference the section on Apply-in-progress Hunged. After following these steps you should be capable of attempting the upgrade again.
Okay, I'm following the guide.
Not sure which PID needs to be entered.  Also the update script listed is unavailable to me.
Here is the output after running the command listed in the troubling shooting guide:
[root@CSPC01 ~]# ps -aef | grep apply
root 19842 19825 0 18:44 pts/1 00:00:00 grep apply
Based on the output there is no installation taking place.
I will send the script in a private message and let our SMEs know the link is not accessible from the guide.
Just following up that I have not received the private message.
The community and private message option will not allow me to send files. Please private message me your email so that I can send the script.
