CSPC Upload Issues
dfinibg6
Hi Community,
Our CSPC is failing when trying to upload the inventory to SNTC portal. Below the upload report:
Phase NamePhase StatusMessage
INITIALIZINGSUCCESSFUL
SELECTING_DEVICESSUCCESSFUL93 devices selected
SEGMENTINGSUCCESSFUL
EXPORTINGSUCCESSFULtransport-inventory-1562213032196.zip
UPLOADING (CSP0009041622)FAILEDTransaction id is empty on TG upload..
CLEANING_UPSUCCESSFULCSP0009041622: Transaction id is empty on TG upload..
Date and Time are correct.
From the CSPC GUI, can you please tell us what setting you have for Settings-->Application Settings-->Export Settings-->Upload Via. If it is set to Transport Gateway please change it to Connectivity and attempt the upload once more, providing us the same output from the logs afterwards.
Thank you
7 Replies 7
Jarrett Pomeroy
Hi There,
Can you please see if the sed commands in this post/details here will help solve your issue?
https://community.cisco.com/t5/smart-net-total-care-portal-and/upload-processing-stopped-after-upgrade-to-2-8-1/m-p/3815676/highlight/true#M10397
Thank you,
Jarrett
Hi Jarret,
We ran the commands and try the upload again but still fails.
Hi There,
Would you be able to send a screenshot of the new upload attempt and/or error message?
Thank you,
Jarrett
Hi Jarrett,
Upload report attached.
Thank you!
Thank you
That worked!.. Thank you.
Great to hear, please let us know if you have any other questions.
