Data Filter Selection limiting Reports
RonF
I am trying to select various reports from the list on the left-hand menu bar (e.g., "Devices | Device Under Multiple Contracts") only to get told "Based on your Data Filter selection, you have no access to this report".  This also happens at times when I make a selection that returns a large dataset (e.g., "Inventory | All Equipment") and then try to use the Search window to search for a particular host.  I can't even find a definition of "data filter" in the User Guide.  What's going on?  Thanks.
Supriya Patel
Hi user,
Sorry to hear on given issue. Please check bug detail below and try workaround mentioned in link.
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvr54849
Supriya
Chrome incognito doesn't fix either.  It's totally hit or miss on whether it will work.
HI,
Engineer team is working to fix given issue. I will update you further as I hear back on progress.
Supriya
