03-26-2019 12:19 PM
Inside the portal it shows data of voice applications of the family Cisco TelePresence Video Communication Server (VCS), there are more applications that can be added to the SNTC portal or only physical equipment can be added.
Solved! Go to Solution.
03-28-2019 08:12 AM
In general, CSPC doesn't collect data about applications running on servers or applications within any network devices. If you see application software reported in the, it's a anomaly and likely has to do with the way the MIB is structured for the hardware. The portal does however typically report operating system information, like the OS verison.
03-26-2019 05:41 PM
Hi Ernesto,
Please check below SNTC PID checker for supported device list. There are two PIDs are supported for VCS family. As per list, there are some virtual Machines are part of the list as well.
www.cisco.com/c/dam/en/us/support/docs/services/sntc/SNTC-PID-Check-final.xlsx
Supriya
03-28-2019 08:12 AM
03-28-2019 02:20 PM
