Firewall permiss to access Cisco Backend
Dear,
I'm install Cisco Collector 2.7 over Hyper-V environment, but no conection Cisco Backend.
When run collect and upload this result is failed.
Please , could send firewall port to access cisco backend and command test connectivity.
Thank
Supriya Patel
Hi Jesus,
Your Firewall must be configured in order to allow these IP addresses, host names, and ports so that the upload processes successfully:
    • 72.163.7.113 (TCP 443) concsoweb-prd.cisco.com
    • 72.163.4.161 (TCP 443/80) www.cisco.com
    • 72.163.7.60 (TCP 443/80) dl.cisco.com
    • 72.163.7.60 (TCP 443/80) dl1.cisco.com
    • 173.37.146.12 (TCP 443/80) dl2.cisco.com
    • 173.37.144.208 (TCP 443/80) sso.cisco.com
Supriya
7 Replies 7
Supriya Patel
Hi Jesus,
Supriya
Hello Jesus,
Please let us know if you need further assistance with this.  If not, please mark Supriya's response as the solution to close the conversation.
Thanks!
Cheri
What's the right way to test if the collector is reaching the Cisco side? I've tried:
"curl https://72.163.4.161:443"
curl: (51) SSL: certificate subject name 'www.cisco.com' does not match target host name '72.163.4.161'
What does it mean?
I see that "curl -k https://[ip address]:[port]" seems to be work.
Hello Daniel,
I like to use this one for testing access (it will also work when a proxy is configured).
'wget https://72.163.7.113/ --no-check-certificate'
Thank you,
Jarrett
Are those ip addresses, ports and hostnames up to date?
Thanks.
Hi Daniel,
For the most up-to-date requirements, please see the CSPC Upgrade Guide, page 1-1 lists the IP's and ports needed for connection to Cisco servers.
Cheers,
Cheri
