How discovery lightweight access-points on collector ???
I am installing a collector, and I can't discovery lightweight access-points.
The lightweight access-points lost the community snmp configuration when are reloaded.
The snmp configuration of lightweight access-points is impossible by controller.
I checked the global configuration of  access-points on controller, and I don't finded the snmp. I can only telnet and ssh configuration.
Collector CSPC can discovery by telnet or ssh ? I finded only by snmp.
Chris Camplejohn
Needs to use SNMP.  Just enable SNMP on your WLC controller.  Here are 2 links to help:
http://www.cisco.com/c/en/us/td/docs/wireless/controller/7-4/configuration/guides/consolidated/b_cg74_CONSOLIDATED/b_cg74_CONSOLIDATED_chapter_0111.html
http://www.cisco.com/en/US/docs/wireless/controller/7.4/configuration/guides/system_management/config_system_management_chapter_0111.html
The device access verification on WLC by collector have succeeded  with snmp v2, snmp v3, telnet and ssh.
The lightweight access-points are managed by trap on WLC send traps to management servers.
Can you send a print of collector with lightweight access-points discovered ???
I realized discovery on WLC with options cdp, nmap, lldap, but the collector can't supply the serial, hostname and model of LWAP.
Are you trying to see the LWAP in the CSPC itself or SNTC Portal?  The LWAP cannot be directly managed.  If you have run a collection that includes the WLC, then go to Reports>Collection Profile Run Summary, locate your collection and click on View Data.  In the "Select Dataset" pulldown, look for "AIRESPACE-WIRELESS-MIB_bsnAP", select it and look at the output.  If it has successfully collected via SNMP, the LWAPs will be listed there.
