01-24-2017 05:29 AM
We have six active Smartnet contracts however only four are shown within SNTC. How do I add the other two?
01-24-2017 07:48 AM
Hello James,
The contracts are reflected in the portal against the devices that they cover under those contracts. You do not need to add contracts to the SNTC portal.
If you believe a device is covered but this is not reflected in the portal correctly then please supply a couple of the necessary serial numbers and we can check.
Regards, Tim
01-24-2017 08:26 AM
Hi Tim,
Can you please check the following devices?
FDO20361DNN
JMX2023L02X
JMX193180FA
FXS1931Q5G0
FXS1931Q54T
FOC1950Z1LB
FGL200440R8
FGL200440R9
Jim
01-25-2017 01:59 AM
Hi Jim,
I have checked the serial numbers. None are in the inventory for your Company name. I cannot see if the Inventory Insight Reports helps as you would need to check using hostname. I check the SNTC Supported Device list and not all are supported so would not show for that reason.
Regards, Tim
Serial Number | Contract | CRParty | PID | SNTC Support |
FDO20361DNN | ending 223 | Company Name Ending in INC | C1-N9K-C9372PX-E | NOT SUPPORTED in SNTC |
JMX2023L02X | ending 223 | Company Name Ending in INC | ASA5585-S10X-K9 | NOT SUPPORTED in SNTC |
JMX193180FA | ending 223 | Company Name Ending in INC | ASA5585-S10-K8 | NOT SUPPORTED in SNTC |
FXS1931Q5G0 | ending071 | Company Name Ending in UK | ASR1001-X | Supported in SNTC |
FXS1931Q54T | ending071 | Company Name Ending in UK | ASR1001-X | Supported in SNTC |
FOC1950Z1LB | ending065 | Company Name Ending in UK | WS-C2960X-48TS-L | Supported in SNTC |
FGL200440R8 | ending065 | Company Name Ending in UK | ASA5545-K9 | NOT SUPPORTED in SNTC |
FGL200440R9 | ending065 | Company Name Ending in UK | ASA5545-K9 | NOT SUPPORTED in SNTC |
